Csi3's as surrounds?
GATOR3000
GATOR3000 Posts: 355
edited October 2005 in Speakers
Present driver setup:
polkaudio Rti8 Front
polkaudio Csi5 Centre
polkaudio Rti4 Surround
Want to upgrade Rti4 surrounds to Rti6’s. I have a spare Csi3 centre.
My question is………….If I would get a second Csi3 and use both as my surrounds how would that sound? Did anyone try this? Or should I just get a pair of Rti6’s to match my front Rti8's and centre Csi5 6.5" drivers?
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Post edited by GATOR3000 on
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    as for as timbre matching I think they'll be all the same. The tweeter matching is the important part. As far as mid-bass and the such yeah it's important but for surrounds you should think about price and what you can get.
    You're going to upgrade SURROUNDS from 4 to 6. You'll receive more extension and I'm assuming better midbass though i haven't heard either of them. I'm not so sure as if this we'll be worth it.
    IMHO I would save the money if you are watching mainly movies and save for seperates, better source, upgraded interconnects, more dvds/cds. I don't think the change would be worth it.
    Usually centers are 3/4 the price of a pair of bookshelves thats a very rough estimate that i've found and so I would probably go with the rti6's rather than buying another center if thats what you want to do. If you took my save money advice if you can just rig the csi3 as rear center.
    Good luck,
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • GATOR3000
    edited October 2005
    Schriss22.............never thought to use Csi3 as rear centre 6.1. Thanks for your suggestion. The tweeters on Csi3's and Rti6's are the same I think. So tweeter and timber match would be same.
    Theatre System 5.1
    Original A8T CD
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    I'm pretty sure they are the same the reason I stated that was because of when you were matching the 6.5 drivers, "Or should I just get a pair of Rti6’s to match my front Rti8's and centre Csi5 6.5" drivers" not a big deal worry about the tweeter more and since they are the same then there is no worry there.
    Good luck if you have any more questions just let everyone know!
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • GATOR3000
    edited October 2005
    Thanks Chris much appreciated.
    Theatre System 5.1
    Original A8T CD
