wtb: coaxial cable
snakebitten
I want to try a coaxial instead of optical on my dvd. Does anyone have one laying around they want to sell. (midpriced)
Post edited by snakebitten on
Hey snakebitten dont buy into snakeoil.....
any rca cable you have will work just fine, there is no benift to buying expensive digital coax cables that all sound exactly the same. -
i will make you one like frank at sigonal cabble for 20 bucks 1 meter shiping
BrentMcGhee wrote:Hey snakebitten dont buy into snakeoil.....
Sounds like someone doesn't pay attention to detail. :eek:
To be precise, any 75ohm RCA cable will work... ie video cables. Granted, for short runs it really doesn't matter so much.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
and you won't be able to tell the difference between coaxial or optical either
well at least I can't. -
Just a few issues about shielding and well fragile'ness?
depends on bends and the such. any 75ohm is correct but not any any rca terminated cable will work. I think signal cable has a in house trail...lemme see...yes they do you have to pay for shipping though. At that price though I wonder if it'll be worth it to ship it back
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Its only about a 4ft run so the way I am understanding it really won't make a difference.
I cracked the yamaha dvd optical slot. Dont remember pulling on the cable but anyhoot it is in getting repaired. I thought while everything is unhooked I would try the coaxial when I get the yamaha back.
Thanks, Ed -
Schris22 wrote:any 75ohm is correct but not any any rca terminated cable will work.
I haven't found one that hasn't worked yet. If you really do have an RCA terminated cable that isn't broken, and won't work for a "digital" connection, I'd like to see it. -
I did have trouble with an AQ copperhead that would not work as a digital cable. Kept losing lock with my DAC. As soon as I substituted a cheapie video cable--BANG--locked on and stayed locked.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
