Rm201 Fronts with RM302 Center
I plan on purchasing RM201 front speakers (they have (2) 3.5" drivers). I was originally going to buy the same speaker for the center, but am wondering if buying the RM302 (it has (2) 4.5" drivers) would be better as the center is so important.
Do you think they match or should I just go with the RM201 as a center?
Post edited by FF&K on
If you already have the 302, then I guess you'd pick up the RM201's off of the polk ebay store, for a BIN price of $149/ pr. Nice set up for the money.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Well the RM30's would be the best match but if you cannot fit them you can certainly use RM20s. They're just a little smaller- but the same product series so they will match sonically and cosmetically.-Eric
-Polk Audio -
Yes you can do that. Just realize the logo will be "sideways" unless you get a different grille too
-Eric
-Polk Audio
