SDA-Helpful Hint for Bad Mid Driver Noise
Dennis Gardner
Dennis Gardner Posts: 4,861
edited October 2005 in Speakers
That bad driver in a multi-mid/woofer setup may not be bad afterall....................
The past week I have been suffering with what I considered to be a bad driver on my SDA1Cs. It smacked, clacked and generally made a hell of a racket when a drum kick or deep bass note sounded at high volume. I couldn't recall any time that I had really driven them too hard or to the point of mistreatment, but it was definately not working in unison with the other mids in the box. Late last night I took the driver out to see for sure what model I needed to look for, I noticed one of the speaker leads had come loose. Hooking it back up, problem solved.
SDA mid drivers in a sealed box/passive radiator design without a signal runnng through them to control excursion become the passive radiator. Being only 6.5 inches, they easily move too far and reach the limit of their travel in a most noisy and uncomfortable sounding smack.
Just thought I would pass on what may be obvious to some here on the forum, but we have had a number of members listening to speakers that are for sale find SDAs that had a mid driver that made racket at high volumes and assumed that replacement was neeed. I found out the easy way, this isn't always the case.
Thanks for reading,
Dennis G.
Post edited by Dennis Gardner on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited October 2005
    Thanks for the info, Dennis!
    I have another helpful hint for those contemplating SDA Xover improvements: replace the damn polyswitch! I'm kicking myself for not replacing, or bypassing, them when I upgraded the SRS and 2B components. I'd never had an issue until I drove the SRSs pretty hard listening to Danielia Cotton (DAMN, this chick can sing!) They tripped once and now trip easily at fairly normal levels. :o
    Mike
  • Dennis Gardner
    edited October 2005
    Oh, my polys are kicking out, at the highest of volumes but I didn't want to do anything until I upgraded the rest of the caps in my crossover. Winter, indoor, snow flying type of job.......
  • Polk65
    Polk65 Posts: 1,405
    edited October 2005
    Excellent tips guys, thanks for sharing. My xo upgrades are also planned for a wintertime activity.
