LP cleaning
Soccerplyr
Soccerplyr Posts: 160
edited October 2005 in 2 Channel Audio
How do all you turntable owners keep your LP's clean. I'm looking for the best way to clean mine without breaking the bank. Say under $40. I've never cleaned mine so some direction on how to do it would be appreciated as well.
Jeff
Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000
Post edited by Soccerplyr on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2005
    Armor-All baby!!! :)
  • madmax
    madmax Posts: 12,434
    edited October 2005
    It's too tough to do for under $40, seriously.
    madmax
    Vinyl, the final frontier...
  • Spawndn72
    Spawndn72 Posts: 453
    edited October 2005
    For under $40... Wash then in the kitchen sink with dish detergent and rinse them in distilled water. BTW I am not joking.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • Emlyn
    Emlyn Posts: 4,535
    edited October 2005
    A Disc Doctor brush and some home made cleaning fluid would get you started for around $40.
    Here's the brush
    Search on Audio Asylum or elsewhere for recommendations on making a cleaning fluid concoction (deionized water, alcohol, small amount of mild detergent, etc). Ken Swauger made some good stuff himself and posted about it a while back.
    It's better than not cleaning them. A vacuum cleaner is ideal. Audio Advisor has a basic Nitty Gritty machine for not too much. It works very well, but of course is more than you're looking to spend.
  • madmax
    edited October 2005
    Sorry, didn't mean to sound so negative previously. It's just that recently I've acquired over 2K records. A big percentange of them "bubble up" when I clean them with the VPI vacuum cleaner. This is not meant to be. Most of the cheap cleaning methods leave more crap in the grooves than if they had never been cleaned. You can never go wrong with at least removing the dust with a nice $25 carbon fiber brush before playing. The Hunt EDA mk6 (I think) brush is a good start. $25 from amusicdirect.com.
    madmax
  • Crazed
    Crazed Posts: 60
    edited October 2005
    Main System:
    PreAmp: Rotel 1098 with MF X-10v3
    Amp: Rotel 1090, 1075, 1070
    Source: Pro-Ject RM9 with Blackbird Cart., Denon 2900 with MF X-DACv3
    Speakers: Gallo Ref 3s (LR), Gallo Due (C, SR, SL), Gallo Micro (RR, RL)
    Second System:
    Receiver: H/K AVR 630
    Source: Pioneer 563
    Speakers: Polk RTi10s (LR), CSi5 (C), RTR 200 (SR, SL)
  • Emlyn
    Emlyn Posts: 4,535
    edited October 2005
    Ebay item
    I thought the old Discwasher LP cleaning brush had been discontinued years ago, but they are still available. These things have been around for decades, and work fairly well. I'd suggest trying a better cleaning fluid with the brush though and making sure the LP is dried of the fluid. The microfiber tends to get soggy quickly, so the brush is usually only good for a couple of LP's before it has to dry out. Should be readily available for under $20.
  • tomhayes
    tomhayes Posts: 44
    edited October 2005
    I have a VPI cleaner which cost about $400 dollars.
    But if I only had $40 and a bunch of dirty LPs I'd take them to the high-end stereo store in town that has the $1000 VPI cleaner and clean them there. They charge 20 cents an lp. Maybe you have a store that has that service where you live.
  • steveinaz
    steveinaz Posts: 19,538
    edited October 2005
    Yep, I did this too, back in the days when I had a turntable. Gets them immaculately clean.
  • Emlyn
    Emlyn Posts: 4,535
    edited October 2005
    Excellent suggestion, Tom. A local snob shop near me encourages this because the owner gets customers in the door to look at other high-end gear. Another suggestion is that once the LP's are clean, stop using the old plain paper inserts in favor of new anti-static plastic/paper ones.
  • madmax
    edited October 2005
    I heard that some librarys also have a VPI or similar. Maybe a deal could be made? I use the VPI, RRL fluid, MF brush and MK6 carbon brush and seriously, after using it I would not consider not owning one. I would consider it a necessity such as a washer, dryer, refrigerator etc at this point. If you wanted some professional cleaning for around $4 each let me know. I include an outside dust cover and sleeve. Overall cost to clean one is about $3 each. Of course once cleaned, they stay reasonable unless you abuse them somehow. I'll always do one for free as a test just for the input. I run my own snob shop. :):)
    madmax
  • unc2701
    unc2701 Posts: 3,587
    edited October 2005
    Emlyn wrote:
    Ebay item
    I've got that exact one- works pretty damn good for the cash, but it takes a little time to get the hang of it. Also helps if you have a spare crappy TT do set the records on while you're cleaning them.
    Backburner:Krell KAV-300i
  • Emlyn
    Emlyn Posts: 4,535
    edited October 2005
    That's exactly the way I used the Discwasher brush for many years until I got a Nitty Gritty vacuum cleaner. :D
    One hand to spin the old turntable a few times, one hand to pivot the brush. It did work very well.
  • janmike
    janmike Posts: 6,146
    edited October 2005
    I remember a guy in residence (school days) that washed them in the tub. This guy would not let ANYONE touch his LP's or equipment. He would then rinse them in cold water.
    Michael ;)
    NORTH of 60°
  • madmax
    edited October 2005
    I normally have mine blessed. :D
    madmax
