HK receiver settings
HuskerTRex
HuskerTRex Posts: 22
I am running a HK635 with Polk's all the way around. I have my HD/DVR cable box running to my receiver with optical cable. When I watch TV, I can never use "stereo" settings on receiver - does this have to do with using the optical cable? When I am on various digital or HD channels, my receiver changes to different dolby digital settings, but the other channels it "defaults" to some PL setting, and sometimes sounds funny - so I basically switch to logic7, since I can't use stereo modes. Just curious about my I can't select stereo mode? Sorry for the yada-yada-yada....
:D
Post edited by HuskerTRex on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2005
    I don't know if you can lock onto just 1 type of output. I think that when a channel doesn't have a Dolby Digital signal to provide, the receiver is picking up the Dolby Pro logic II. I do know that you can choose default processing for the signals in your onscreen setup. I would start with the setup in the receiver. No need to change out the optical cable since you are getting sound, just try different settings in the setup.
  • HuskerTRex
    edited October 2005
    I will give that a whirl.
    Thanks!
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    Have you tried a direct setting? Not quite the same as stereo but similar.
    I'm not familiar with HK but my onkyo has a direct setting. I would agree in checking out settings to see if it auto locks into best signal feed. So good luck
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2005
    Try pushing the "Surround On/Off" on the remote and or the face of the receiver.
    The problem MIGHT be because you are using the digital optical, instead of the L/R analog.
    Logic 7 is a gift from the gods of Lexicon.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
