Need help with MC1 trigger and Monster
warlocks1
warlocks1 Posts: 1,284
edited October 2005 in Electronics
I need to construct a trigger cable from my Lexicon MC1 to a Monster HTS5100 surge protector. The Monster uses a 1/8 inch miniplug and the Lexicon uses 2 bare wires (power and fround) or a 5 pin DIN connector. Anyone know how to make the cable? Thanks, Jeff
Post edited by warlocks1 on
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2005
    Well, man, I was all set to help you out. This sorta thing is just up my alley...and then you said the Lexicon uses a power and a fround?! Man...I'm lost. Hope you can figure it out 'cause I think you're gonna be on your own with that one!!
    ;):D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • warlocks1
    edited October 2005
    Soo sorry, I flunked typing in high school. I found an old post from SMR forum that said to cut one end off a minplug cable and seperate the two wires. Connect one to the 'GROUND' and one to the power. I will give it a shot. Thanks for the help. :)
  • millenniumrx2
    millenniumrx2 Posts: 52
    edited October 2005
    audiobliss, what listening mode do you use for 2 ch listening with the yamaha?
    classe ssp-25,parasound 2205a,hk tl8600,samsung hd-dvd,lsi15,infinity hps-1000
