Suppose I used R30 towers for front & rear center speakers?
edited October 2005 in Speakers
What if I used R30 towers for front & rear center speakers? My system as it
currently stands: R50 towers front, R20 rears, and a PSW12 sub. It seemed
more cost effective to grab a pair of the cheap R30s, but how would they
perform as center speakers. I'm using a projection system HT, so the R30s
would sit on the floor, just as their design intended. Driving receiver will
be something of the 100 watt/channel 6.1 variety. Room is probably
22X36. What say ye Polk experts?
Thanks,
Gort
Post edited by Gort on
    edited October 2005
    it would look funny but there is nothing wrong with it. R30 as a rear is fine. just might need to elevate a tad bit.
    If you could a CS1/3 Csi25 or another r50 as a front would be more important.
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
    edited October 2005
    I have used an R30 as a rear center with R20 surrounds, and it works well. You should put the R30 on a table or stand, so the tweeter, is close to the height of the R20 tweeters (a little lower is okay).
    As for the front, I don't know, never tried an R30 as a center with the R50s. Three R50s does make a solid front, with good impact.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
Welcome!
Welcome!
