Polk Marine Speakers
Erik
Erik Posts: 5
edited October 2005 in Speakers
I bought some Polk Marine Speakers about 10 years ago and had them in my boat. I've not used them since but I wired them up to my home theater amp for outside on the deck. Before connecting I looked for the impedance/ohms. They don't say, so I measured them individually w/ a meter and they read 4.8ohms. Does that mean they are 4, 6 or 8? The reason I think they could be 8 is my home theater speakers say 8ohms on them and they read 4.2ohms. Any help is greatly appreciated.
Post edited by Erik on
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    Whats the model?
    see if you can find it here
    http://www.polkaudio.com/search/older_car.php
    I know it says older car....but it's in the car and marine part of this homepage. You can email polk and/or try a search online.
    Good luck
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • Erik
    Erik Posts: 5
    edited October 2005
    They are:
    Polk Audio
    M2AW
    02686
    Thanks so much for the link, I couldn't find them there. I'll have to do a search or email Polk.
  • Erik
    Erik Posts: 5
    edited October 2005
    I don't think the're car speakers. They are pretty big like a small bookshelf speaker and have a mounting bracket w/ 2 keyholes to hang from 2 screws. They hooked them up to my stereo in my skiiboat though that's why I figured they were rated for car stereo impedance.
  • Schris22
    Schris22 Posts: 983
    edited October 2005
    so these are recessed speakers or bookshelves? I just pointed you to car/marine because it's the same section in polk. try looking in an older models of polks home audio.
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • Erik
    Erik Posts: 5
    edited October 2005
    They look like some of the newer Polk and most brands outdoor type speakers. There's a little swivel bracket on the back with a keyhole type mounting hole. You put 2 wood screws in a wall and slip them in the hole and pull down to lock in.
  • Erik
    Erik Posts: 5
    edited October 2005
    This email came from Polk Customer service. Thanks for the help guys!!!!! BTW, I found on the web some info that said to multiply total ohms of a speaker [disconnected of course] by 1.3 and that gives you the total ohms. That makes sense to me.
    Eric,
    These are 6 Ohm speakers. 4.7 Ohm is the DC resistance of the drivers
    voice coil.
    Thanks,
    Kim
