odd behavior w/ my receiver and SDA2s
nadams
Just noticed this tonight as I went to turn my speakers off to watch a movie w/ my headphones... I power the headphones through the receivers output, so I usually just turn off the "A" set of speakers, and that way I'm not annoying everyone in the house.
Well, I found today that when I turn off the speakers, the SDA drivers still output signal. What's up with that? How are they getting anything? Obviously my receiver doesn't like something about the interconnect, but I'm not sure what...
Anyone have any thoughts?
Ludicrous gibs!
Post edited by nadams on
When they start spewing green pea soup, back away quickly.
Sounds like the ground is making its way back through your speaker selector switch. Basically a feedback signal.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
That's odd... and thoroughly annoying. I've been looking around for the method to check and make sure your SDA is working, but I can't seem to find it. Everyone just saying call Ken and he'll mail you one. But I want it now!Ludicrous gibs!
http://www.polkaudio.com/forums/showthread.php?t=31752&highlight=sda+troubleshooting
Check post 13 by thehaens@cox.ne in this thread.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks, SCompRacer!
BTW- If I unplug just one end of the SDA interconnect, then this problem is no longer there. It must be something having to do with the common ground thing, then...Ludicrous gibs!
