Tubes for your computer? Huh?
rnp614
The don't actually say whether or not it made a difference in sound.
BTW- this isn't the first time tubes were implemented in a PC device. Aopen made a motherboard a while back that had a tube on the output stage of the soundcard. They didn't make very many, and I've never seen them in use or for sale anywhere. There are some reviews out there, though.Ludicrous gibs! -
nadams wrote:BTW- this isn't the first time tubes were implemented in a PC device.
Drrrr. I believe the first PCs were nothing but tubes. :rolleyes:
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I meant in the audio sense there, audiobliss... When those computers were all vacuum tubes, there wasn't much in the way of audio!Ludicrous gibs!
Talk about cool!
Really going to debate whether or not to get one. -
haha thought some people would want it
audiobliss wrote:Drrrr. I believe the first PCs were nothing but tubes. :rolleyes:
lol. Thats what I was thinking. -
Fortunately, the state of the art in vacuum tube computing is still impressive ;-)
http://www.ominous-valve.com/vtsc.html
the tube it uses loks like a 12ax7, but no where do they mention what it isPicking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
Uh, no PC's used tubes (except in these weird cases we're talking about). Tube computers were too large and expensive to be bought/stored by indivduals. PC's came about once silicon chips could make computers small and cheap enough for the mass market. drrrrr...
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Probably... I suspect the circuit's similar to PAIA's "Tube Head", a more or less plate-starved 12AX7 to warm up cold, sterile digitally-derived source.
http://www.paia.com/tubestuf.htm
Well, that's true IF one is speaking of digital personal computers. But computer don'ts gots to be digital!
Heathkit, for one, made several different models of analog personal computer kits with vacuum tube op-amps. I actually owned one of these, briefly. Should've kept it, as they're quite collectable today.
http://www.heathkit-museum.com/computers/ec-1.shtml
FWIW, this isn't the one I had. The one I had was wedge shaped, with the op-amps in back on the top. It was about the size of a roll-top desktop. :-)
I read a review, the computer audio thing takes a 12au7 tube.. soldered in, so a socket would need be installed to change it and the website doesnt even mention what tube it takes.. it's top secret because no article or specs mentions the tube. weird
I already want one to put inline with my SI/passive integrated i just made. 12volts to power it and it has 1/8" jacks for in/out put remove that stupid meter and tube display and just use the board inside and the tube boardMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
why would u solder in a tube, theyre meant to be changed over time....Picking ones nose signifies a strong sense of self discovery
a signal tube like this will last a long, long time (assuming it's a good quality tube to start with)... soldering a tube in isn't really any different than soldering in a transistor or an IC.
Yes, remember, this is only to add color to the sound. This isn't to actually drive anything. Power tubes have a much shorter lifespan... and besides, we're talking about low power levels going through it, period. Your soundcard doesn't put out much power
They probably don't make mention of what tube it is, because the average consumer wouldn't give a crap...Ludicrous gibs!
