an annoying buzz
francour
My all polk 7.2 system is almost perfect. 1 sub (Split out of 1 output) has a very soft hum. It does this regardless of being hooked up, even when the power switch is off. I have replaced the driver, but no change. Any ideas? It is only 1 of the subs that does this.
Post edited by francour on
I had the same problem at work, it was a result of the subwoofer cable having a loose connection. Try a different cable, that might work. Other than that, I'm not to sure what else would cause it.
Thanks for the advise. Unfortunately the sub hums even when no sub cable is connected.
So the sub hums when no cable is hooked up and when it's turned off?
yup. if the sub is plugged in (any outlet) it hums, whether it is switched on or off.
IS it a Polk sub, which model?
The only other thing that I can think of is that your amp might be going out. In that case, if you still have a warrenty on it, have it fix. If not, it might be time to buy a new one. Sorry that I couldn't provide more help.
the model is psw303
the model is psw303...
Is the sub grounded? I had some humming problems with the sub in my CS1000 center channel. At the advice of Polk tech support, I added a converter on the end of the cable to convert from 3-prong to 2-prong (no ground). Problem solved!
If that doesn't work, you also might try a ground-loop isolator, especially if you have cable TV. That can introduce interference into the line.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
thanks for the advice... i will try both steps and post the results in the next day or two.
