Woofer MM365 doesn't move
erickoe
Hello,
The right woofer of my Polk MM365 doesn't move anymore but gives sound less powerfull. (almost no bass)
It looks like is freezed or glued.
It happend when I checked it because i heard a strange sound thru my music at every soundlevel.
For a long time it sounds like there was something touching the dustcap.
There was some corrosion sticking at the magnet when i removed the magnet cap.
Is the woofer declared dead?
Is there something i can do to fix this problem?
Post edited by erickoe on
Yeah, it's history. Call our CS department at 800-377-7655. They should be able to help.
I'm from the netherlands.
What does a replacement woofer cost? -
I have no idea. You'd have to call the customer service line. 800-377-7655
