FXi5 Speaker Stands
miketech
What would you guys recommend as good Speaker Stands for a pair of FXi5 speakers?
Mike
Mike
Post edited by miketech on
I assume you are asking this question as you dont have a way or a spot to mount them on the walls? Just getting some clarification.
That is correct, they would not be spaced apart very well if I mounted them on the wall. The room I have my home theater in is not very symmetrical and has many windows.
