Computer Sub Choices....HELP MY FELLOW BRETHREN
Schris22
I'm trying to find a computer sub for my r15-Onkyo rig....playing games and certain music really need something more...r15's are an upgrade from my other speakers but in my 2.1 logitech's I had a sub....now I have better highs and mids but not as much bass extension.
I was orginally going to build a small sealed sub, but I'm not sure which components and I really need a lot more motivation to build it...but...here are my options...I'm aiming at 150...but 175 if it's highly recommended...I'm going to post in my rank...
1. Advent 12''
2. KLH 10''
3. Velodyne VX10
4. Mirage Nano Sub
5. Athena Sub 8
6. Build My own Super duper easy Sealed sub for 150 or less...
7. See what happens with this local auction...Link
Or should I just wait around ebay for a used one...though i don't like the idea of buying used subwoofers....
EDIT: This one is local in Houston I can make the 3 hour drive to pick it up and visit home... http://houston.craigslist.org/ele/97172536.html
AND Just found this one...anyone know anything about AR Speakers? not sure if it's the same as the cable company LInk hope this works
Anyhow! Thanks again
Hmmm just had a thought about replacing my current Home audio sub and moving that one to my computer rig....But I don't think I ahve enough money to upgrade past that and I think my dayton is doing a good job for my dorm room...
Chris
1. Advent 12''
2. KLH 10''
3. Velodyne VX10
4. Mirage Nano Sub
5. Athena Sub 8
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
Mmmmmm,
You made it super duper easy for me to choose one but I'm not familiar with any of them.
Good luck with your search anyway....if you don't get any replies maybe that means save another hundred or so then go a little higher up the quality/size ladder.Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
Heck Chris,
Just get another Dayton 10 or 12 and put the 12 into your HT.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
another dayton eh?
I am impressed with the preformance of this one.
But the price of that advent is so cheap...
It is also really cheap everywhere not sure of the sudden price drop.
ChrisReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Anyone know anything about the ARPR808
It's an Acoustic Research Sub and it looks great and well on paper the specs are nice...
It's semi compact too!
Uses 1 8'' Passive radiator and 1 8'' Subwoofer
Product Info
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
I recently update my gaming computer with Klipsch Quintent 2 and bought a Infinity PS-10 sub(I think it sells for $249 shipped at vanns.com)
Recently amazon had a Klipsch KSW-12 for $249 shipped.
I would ideally like to have SVS PB-10 or an HSU equivalent.
With all the new games coming around it would awesome to have good sub.
If you can spend a little more buy a better sub and never look back.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
