cable fitment question
marcpam
I have a sub cable that seems to fit looser than I would like on my sub. I am refering to the lfe cable. Is there a way that you can squeeze the ends to make it fit on the input of the sub better, or will it hurt the cable?
What is the best way to get the cable to fit more firmly?
Post edited by marcpam on
no idea....
maybe that sub cable has been worn out for a while? or poorly made...did you just get it?
Might be time to buy a new sub cable...
Sorry i wasn't of real use..
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Schris22 wrote:no idea....
Chris
the cable is specifically for subs, it is a monster z-series. Set me back over $100. I won't buy a new cable and I don't think that it is worn out or poorly made. Anyone else? -
I'm sorry.... but did you say "fitment"?If you will it, dude, it is no dream.
marcpam wrote:I have a sub cable that seems to fit looser than I would like on my sub. I am refering to the lfe cable. Is there a way that you can squeeze the ends to make it fit on the input of the sub better, or will it hurt the cable?
I interpret that your cable's RCA male doesn't "crimp" on the sub's RCA female tight enough. If so, I don't see why you can't squeeze the cable's rca jack a little. It won't hurt the "cable", but if you squeeze too much, you may break the RCA jack (don't ask me why I say so :-)).
-fredv- -
marcpam wrote:the cable is specifically for subs, it is a monster z-series. Set me back over $100. I won't buy a new cable and I don't think that it is worn out or poorly made. Anyone else?
well alrighty then..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
you can squeeze the cable connectors to make it fit tigher.. it will not harm the cable or the subwoofer. just don't make it so tight that you can't remove it when needed.PolkFest 2012, who's going>?
It should be fine. We do it at work all the time, and we haven't notice a difference yet.
Obviously, you have a problem with either the cable rca or the sub rca. Try the cable on a different rca jack to see if the cable rca is the problem. If it fits snug on another rca jack, then the sub rca is the problem. Report back.Political Correctness'.........defined
