Nissan Frontier speakers, what will fit?
Willy Doer
Willy Doer Posts: 5
edited October 2005 in Speakers
Hi,
I have a 2001 Nissan Frontier crew cab and I'd liek to replace the stock speakers with something good to go with my Alpine head unit.
I'm considering 5.25 and 6.5 MOMO's, does anyone know if these will clear?
I'd hate to spend the money just to find that they won't fit.
If not, what other Polk speakers would work?
Thanks,
WD
Post edited by Willy Doer on
  • unc2701
    unc2701 Posts: 3,587
    edited October 2005
    Crutchfield.com has a database of what fits... just got put in your model & it'll tell you which polks will go in there.
    Backburner:Krell KAV-300i
  • Willy Doer
    Willy Doer Posts: 5
    edited October 2005
    I was there ealier, Crutchfield says I have 4" rears and I don't, they're 5.25's.
    I'm more worried about depth than I am width.
    WD
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2005
    Wrong forum bro. Go Here.
    But to answer your question, you have 6.5's in the front door and Im not sure but I think its 5.25's in the rear.
    The Momos should fit just fine and even if they dont it wont be by much. A simple spacer could remedy that in no time.
  • Willy Doer
    Willy Doer Posts: 5
    edited October 2005
    Yes, you're right, they are 5.25's in the rear, thanks for the pointer to the correct forum.
    Wouldn't a spacer take up more room where depth is concerned?
    WD
  • MacLeod
    edited October 2005
    No. A spacer would mount to the door panel and pull the speaker out.
