POLK VS VELODYNE speakers
WHO puts out the best monitor speakers is it velodyne or polk.
how about the wattage trying to compare the differance.
thanks
thanks
Post edited by gadgetman on
Why not ask on the Velodyne forum?
Whats wrong with asking in polk forum?Main: 2xLsi15
Center: Csi40
Surrounds: 2xLsi7
Back centers: 1xcsi30
Subwoofer: SVS PB10-NSD
Asus STX sound card -> Harman Kardon AVR325 -> Adcom Amps -
The best thing to do is find a shop that has both speakers & demo both & decide which you like the best.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
aaharvel wrote:Velodyne makes Speakers?
not sure he was referring to something like this http://www.velodyne.com/velodyne/products/ob_products.aspx?sid=578y102w
-fredv- -
in my opinion, Velodyne hands done makes the best
high end subwoofers. If you are looking to spend under
$1200 for a subwoofer then SVS or HSU will give you great
bang for the buck.
I haven't head the polk or velodyne satellite speakers - I
would listen to both and then make a decision.Pio Elite 60 in 1080p PRO-150FD KURO
Integra DTC-9.8 - Pio Elite BDP-95FD
Cinenova Grande 3 ( 600W x 3 ) - Polk LSi15s, LSiC
Outlaw M2200s x 2 ( 300W x 2 ) - Polk LC265i x 2
Velodyne HGS-15X -
tdeluce wrote:in my opinion, Velodyne hands done makes the best
bang for the buck.
agreed. I haven't heard anything that comes close to the 1812.
And i'm not just talking about 13hz and a certain SPL- but the way the bass is delivered. Cerwin Vega 15" subs can play loud and low- that doesn't mean they sound good.
