Vintage speakers as mains for HT
Shadow_Ferret
Shadow_Ferret Posts: 1
edited October 2005 in Vintage Speakers
Hi,
My very first pair of speakers were a set of Monitor 5's (or maybe 7's, it was almost 30 years ago!). I've owned many speakers since, but I feel they were the best sounding speakers I ever owned. In that vein of feeling nostalgic I plan on buying a pair off of Ebay. Since I'd also like to move into the home theater realm, I was wondering if Polk Audio has any recommendations for timber matching their current line of center speakers with these vintage speakers?
Thanks.
Post edited by Shadow_Ferret on
  • Phil Dawson
    Phil Dawson Posts: 288
    edited October 2005
    Check with the tech folks at polk. They are a lot of help and you can do what you want to do at least with some of the older polks. Keep in mind that you will probably want to match at least driver sizes and type of construction. Welcome to the forum.
    Good Luck, Phil
    5.1 Music rig:
    SRS SDA front
    2.3tls rear
    2 cs400i center
    Shure 12" sub
    2 PSE mono blocks and 1 stereo amp front
    2 PSE stereo amps rear
    1 PSE stereo amp center
    Mac 2100 bridged to mono sub
    B&K ref 10 upgraded to ref 50 pre/pro
    Harmon Kardon Citation tuner
    Pioneer tuner for AM
    Pioneer DA-45 universal player
    Sony X7esD CD player
    Technics 1200 TT
    PSE pre amp for the analog stuff
  • ohskigod
    ohskigod Posts: 6,502
    edited October 2005
    I went this route at one time, has a pair of RTA 12's with the peerless tweet. find out what tweeter you have, then find a pair of the smaller bookshelfs with that tweeter Mon5's etc (thats what I used) works fine. I think the older CS400 will be fine too, not a timbre mnatch, but it will work nonetheless
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
