My Laptop died.....
brettw22
So I was at work today and had my laptop in the car and the battery died so the thing shut off. Not a problem generally, but it won't boot back up. I finally got my digital camera to tkae a picture of the error message that was popping up and here's what it says:
UNMOUNTABLE_BOOT_VOLUME
Basically, my hard drive can't find where to boot from and it's about dead. I'm on a desktop right now, but I HAVE to get this laptop back up and running by this weekend. I'm heading out of town next week and there's a TON of stuff on it that i need to get.
I guess one option is to connect the laptop drive to the desktop and try to read it as an additional drive on the desktop, but I'd have to get some sort of adapter cable to connect the 2.5" drive into the mix.
Any ideas? Thanks in advance..........
What is it with you and computers
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Could be the boot.ini is hosed. What op system is it? If XP, you can put in the CD and try a repair. Repair won't wipe the drive out.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Running XP Home......i have to find where the hell the cd's would be after this move.........ack.comment comment comment comment. bitchy.
you should be able to download your stuff from one hard drive to the other..
Try to plug it into the other computer as an external drive...
or a second slave drive...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Go into your BIOS when it first turns on, select HDD for first boot device.
mine crashed a month ago, lost about 7 months of data (got too lazy to backup, expensive lesson). The silver lining: with a new drive, booting up now goes very fast.
CompUSA carries the small HDD to regular IDE adapter. As long as the partition table info is intact, you should be able to retrieve the data. You need to find the spec details on that HDD to reconfig it to a slave drive. Good luck, I know how it felt. I was there a few weeks ago, and just barely finished reinstalling all the softwares. Now, I backup the data to my home pc, at least once a week, if not more. I found a nifty program made (free) by uncle Gates: SyncToy.exe (part of powertoy XP tweaks) that can be run with scheduled tasks program, to synch my laptop's data directory with my home (desktop) machine.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Worst case is you go to Frys or wherever and buy one of the external drive kits for the laptop drives for like $25, hook the drive into that, plug that into a second computer probably via USB2, copy all your files over to second machine, and do the system restore thing on your laptop...
yeah, or you can edit the boot.ini file (if it messed up) by plugging it in to a different computer.Polkmaniac wrote:Worst case is you go to Frys or wherever and buy one of the external drive kits for the laptop drives for like $25, hook the drive into that, plug that into a second computer probably via USB2, copy all your files over to second machine, and do the system restore thing on your laptop...
I would say, check the boot order... it might have gotten jacked. Make sure the hard drive is set as a boot device. -
hard drive is set as the primary boot device....
If the boot.ini isn't working properly, i don't know that there would be any functionality of USB if it can't even find the files to load drivers, right?comment comment comment comment. bitchy. -
Give this a read and see if it helps, Brett. Best bet would be the repair option from the Windows install CD IMO.
brettw22 wrote:hard drive is set as the primary boot device....
Find your XP disc. Set the CD-Rom as the first boot device and boot it up with the disc in there, and choose the repair option. -
Yep, boot off the CD, when the first prompt comes up press enter, when the license agreement comes up press f8, then it should detect your previous installation of windows and ask you if you want to overwrite or repair, and you press "r" to repair.
Unless you have a crappy OEM disk that just has an image of the machine from the factory, in which case you might be screwed on that route.
Chances are, nothing is wrong with the hardware, it's simply the fact that the system did not tidily shut down and some files got corrupted.Ludicrous gibs! -
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Well well well........what a PITA........
I went to the Fry's here and bought both an internal 2.5" to 3.5" adapter and an external USB housing for the hard drive. I ended up trying the external first and it did get recognized by the tower I'm running Server 2003 on (but not for about 12 hours, which was weird). I couldn't access any of the information on the drive, but it was at least showing up in explorer.
I ran a "chkdsk e: /r" and after that completed, I was able to access the files on the drive via explorer. I then took the drive and re-installed it into the laptop and I was at first furious that it came right back up to the "windows was shut down unexpectedly" screen that I couldn't get past previoiusly. I was thinking I was just about to kick the thing, so I figured what the hell I'll select "Start windows normally" and I'll be damned if the thing didn't finally come up.
It's up and running and all is good with the world.......:Dcomment comment comment comment. bitchy. -
Congrats."SOME PEOPLE CALL ME MAURICE,
Time to kick back and groove to some Wynonna! :eek:
internet streaming techno to keep "Project Clean Apartment" going....:Dcomment comment comment comment. bitchy.
very cool there Brett. good work man.PolkFest 2012, who's going>?
