carver m200t- lsic
opus
Its been awhile since I posted an insanely stupid question and I just can't wait any longer...
I have a M200t (Fm purchased) hooked up between my 3805 and my new lsic.
1. I am running from my single center channel preout to the left/right inputs on the carver.
2. Then from the left output to the upper posts and the right output to the lower posts of the lsic.
My question: Is this the best way? Would I gain anything by running the carver brigded?
I think I have it right but would hate to miss something easy because I'm afraid to ask.
Thanks........kevin
Thanks........kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Hitachi 50VG825 LCD
LsiC, Fxi30's
Post edited by opus on
opus, I'm assuming that you are using a Y-splitter or you receiver has 2 center outs?
I would do it (in fact, I did it for quite awhile) the same way you are. It's a better option than bridging. One, You don't need that much power, two, the LSiC is a 4ohm speaker and bridged, the m200t shouldn't see less than 8 ohms. I think it would WORK, but why bother?
TroyD,
Thanks for the reassurance, If I read the Fm history books correctly you owned this amp at one time. Small world.
kevinThe Flea rig
Hitachi 50VG825 LCD
-flea market
LsiC, Fxi30's
