help! need tweeter replacement for rt2000p
godofgamblers1
today i juss notice my right speaker the tweeter was dead on my rt2000p, i need to noe how much is it to replace both my left and right and is it hard to do?, i am currently powerin them with denon avr 4800, regular 12gauge cable to power the mids and highs , and rca subwoofer cable from the front left and right preout to the left and right of my rt2000p line level input,all cables are by monster cable currently have the front set large, and center to small, sub and rear off since i dont have them speakers.
Call Polk CS. I'm not sure if they carry that tweeter anymore. Or you could steal it out of a dirtbag rt35i you find on ebay or something. I think they have the same tweeter. Good Luck.
Had the same thing happen awhile back. Polk sent the replacement tweeter, but not the tri-lam. They said that there were no more in stock. I actually switched it for the one in my center channel (cs400i). I wanted the mains to have the exact same type of tweeter. Good luck
Bummer. You can't get new trilams anymore (sniff sniff). You have to replae both, or scrounge one up.
you could look for a beat up cs400i. probably easier to find then one rt35i
