MM120 Box
LowRam
Whats up,
I just purchsed 2 mm120's and I am planning on building a box for them. I read the manual but it didn't make too much sence to me. Each enclosure needs .88 cubic inch. I understand that. The example they gave me in the manual came out to 1.02 cu in?? Anyways I figuer all I have to do is take .88 times by 2 by 1728 then divide that number by 3 dimensions. But my question is... do any of the dimensions need to be a certain size? Does the depth need to a size? do I need atleast 14" for one side? I guess what I'm looking for is the best sounding size for a sealed box for two mm120's. Thanks!
LowRam
LowRam
Post edited by LowRam on
