Either I'm not very bright, or....
Ok I picked up some Pioneer CS-X5 bookshelf speakers from a garage sale. The specs on em are:
4" Full Range Cone Type
8 Ohms
100 - 20,000 Hz
Maximum music power 30W
5.5" x 7.5" x 5"
3.1 lbs
Ok anyway, they have normal + and - connectors on the back, so I grab some speaker wire and hook them up to my reciever, and I get no sound at all, nothing, then I tried another amp, still no sound at all, just as if I didnt have them hooked up, cant hear any pop or crackle or anything from them, just nothing.
Either I'm doing something wrong, or since these are surround speakers for a Pioneer system they will only work with a Pioneer system? Anyone wanna chime in?
Thanks.
8 Ohms
100 - 20,000 Hz
5.5" x 7.5" x 5"
3.1 lbs
Thanks.
Post edited by dohcmark8 on
pop open the lid, take out the biggest woofer and look inside. See if everything (anything) is plugged up...
Could be a blown crossover.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote:pop open the lid, take out the biggest woofer and look inside. See if everything (anything) is plugged up...
Don't think they would have a crossover, they are full range and just have one big driver?
Possible that somehow Pioneer made them so they only work when hooked up to a Pioneer reciever as rear surrounds? -
Has anyone ever heard of speakers only working with a certain receiver?
Oh well I could use the enclosure, anyone recommend or got any decent 4" (100mm) full range drivers on the cheap?
Thanks. -
Is the speaker (the woofer) plugged into the terminals on the back?
If not... thats your problem...
They could have a short - if they are plugged up.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Try parts express for replacement full range drivers. They should have a few to look at and at reasonable prices."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Thanks I will check out parts express.
Sid - I popped the speakers open, tried hooking directly to the driver, still nothing. They are blown I guess.
Anyway, I'm just gonna order some nice full range drivers, I like the enclosure, it looks nice. -
pix?Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
peersool wrote:pix?
Only ones I could find were off an eBay listing... http://cgi.ebay.com/PIONEER-CS-X5-BOOKSHELF-SPEAKERS-black_W0QQitemZ5799187927QQcategoryZ14991QQcmdZViewItem -
I have never heard of any speaker designed for just one type of amp.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Only those type that are designed with a built in amp (car audio ala Bose) comes to mind.........box speakers will take any signal, just like your phone doesn't take phone calls from only Panasonic Phones.....comment comment comment comment. bitchy.
Thanks guys. I'm just glad I'll always have my RTA-8T's to enjoy.
Order your replacement drivers HERE.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Did you check the resistance with your multi-meter? Just wondering...
It'd have been really easy to fry those little things though, so you're probably going down the right path...
CW
