Recommendation for rear surround
cornpornboy
Just wondering what speakers you guys recommend for 6.1/7.1 Surround back rear's.
Will the FXi's do the job or would you recommend a bookshelf speaker.
Post edited by cornpornboy on
What speakers do you have for the rest of your system? I ask that question because it made a world of difference for me to be timbre matched and diffused. Makes the sound flow effortlessly.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I would go Dipole/Bipole for the rear surrounds and bookshelves for the surround back. for 7.1. For 6.1 i would buy the same center you use up front to use in the back.
Harman Kardon AVR 330
all polk
rti10
csi5
fxi3
SVS pc plus 20-39 -
I have the rti-38s in the back and they sound pretty nice (the openning scene in Saving Private Ryan brings out the best in my surround set up).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
Movies that acutally have a discreet track for the Bk. Surround use many transient type sounds for this channel. Its best to use some type of front firing speaker for this. The catch is most DVD's do not have this discreet track, so your processor matrixes a sound track for the Bk. Surround, which usually is more ambient so the FX speakers work well with this, see its a catch and the resulting confusion/debate. I use front firing Bk. Surrounds with F/X side surrounds.
RT1 -
I use just a 5.1 setup right now. I've used 2 different sets of FX speakers (ls/fx and currently fx1000's) and have been happy with both. The bigger the mid speakers in the rear, the more FX details you hear.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
Sorry everyone, I had no intention of creating a very lame rhyme in my previous post and apologize profusely.____________________________________________________________
well ok, just dont do it again
Also, the size of the speaker has little to do with what gets output, if you are talking about ouput in relation to power, then the applicable spec would be the efficiency rating of the speaker.
RT1
