Will the mmc6500's ever sound as good as my rti4s?
KrazyMofo24
I just got the mmc6500s, but right now the rti4's blow them away in sound quality. I have the mmc6500s hooked up to just the hu. Will a good amp be the solution to have them sound as good? Or is it that home theater speakers are better?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
RTi4's are outstanding period.
Also, is your enclosure volume for the 6500's as big as the RTi4's? -
Definitely not when running off the head unit. A real amp should improve the sound quite a bit. Although the answer you're looking for is probably never, unless you really want to dedicate some time to rebuilding the interior of your car.
aaharvel wrote:car audio vs. home audio... apples and oranges
unvalid and unfair comparison as far as I can tell...<|> -
Lets make this a fair comparison...
Take a chair, and your RTi4 and lay it on the floor in a corner, and you sit about 1 foot away infront of it...
Sound closer?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I know its easier to make home speakers sound better than car speakers, but their still is $1000/pair car speakers I don't think anyone would spend that much just to get quality that equals a $240 pair of speakers right?Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
I imagine if you put them against the RTi4 in an enclosure and put them at ear level, pointing at you - with a well designed baffle, proper - sealed and tuned enclosure...then YES - it would surpass it probally...
But...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Dont forget all that wonderful glass and hard plastic that does such wonderful things to sound quality.
Even if you were to take an identical set of RTi4's and install them in your car they wouldnt sound as good and the primary reason for this is all that gawddamned glass and hard plastic reflecting everything and degrading the SQ with every reflection.
Still once you get an amp on those speakers, let them get broken in a bit and fine tune them some they will start to sound much better. Fear not, the MMC6500 is the best speaker on the market under $300.polkaudio sound quality competitor since 2005
MacLeod wrote:Fear not, the MMC6500 is the best speaker on the market under $300.
I want them so BAD!!! Would any of the Polkies ship a set to Costa Rica...?<|> -
Call Polk CS. They sell them factory direct and they might be able to send someone down to the local UPS store for ya.polkaudio sound quality competitor since 2005
Yeah, you need an amp and give it some time to break in.LSIm system on order =D
Currently listening to innovation...
Prior car systems:
Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500 -
KrazyMofo24 wrote:but their still is $1000/pair car speakersNever kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
About 125-150 wpc and 60-70 hours of burn-in will, most likely, have you singing a different tune."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
