monitor 12's on the bay :)
nadams
I just like the looks of these... I wonder if they would've benefitted from an additional tweeter, though. I've never heard any personally.
I'm not sure if the following specimen has the original PRs, or if they were replaced with active woofers. They don't have the donut weight on them...
Item # 5813318044
no affil.
Item # 5813318044
no affil.
Ludicrous gibs!
Post edited by nadams on
The monitor 12 series 2 speakers had the SL2500's from the factory. If you look closely, you can see the foam rings around the domes that are unique to the 2500.Ludicrous gibs!
nadams wrote:The monitor 12 series 2 speakers had the SL2500's from the factory. If you look closely, you can see the foam rings around the domes that are unique to the 2500.
My bad.Thanks.
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
From the description:
"The surrounds on that speaker are also all fine, but for some reason they're dusty. I doesn't effect performance, just looks. If you want to clean them up with some armor all, feel free." :eek:
Or not.
