20hz Or 16hz?
Pinktulip7
Mu sub set to default 20hz...if I change to 16hz with port block,is it make any difference? :eek: :eek: :eek: :eek:
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
It will play four cycles lower. Duh.
Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
What do u mean?
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
You will have a *slight* loss in output overall... and it will hit lower.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I liked the sound better with 16Hz tune. I might try 12Hz as my HT room is quite small for PCU (14x12) and I don't listen at reference anymore.
The smaller the number the lower the notes.Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
Pink,
Below the 20hz range, your subwoofer will produce sounds that you "feel" more than hear, the shaking of the couch or that rumble in your chest. I have my subwoofer set on 16hz with one hole plugged because I like to feel the bass. To me, feeling the earth shake is as exciting as hearing the roar of the earthquake.
Now that being said, not all movies play sounds below about the 25-50hz range since people cannot really hear it and most cheap subwoofers cannot produce it. However for those movies that do have those sounds added, and if you have a sub that can handle it, you will definitely experience the movie as well as hear it.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
You will lose output from about 19 Hz up but gain output from 19 Hz down. You gain access to maybe 0.1% more effects from movies so unless you really dig big church music, you probably won't notice the extension advantage. Some have noted that the sub sounds more controlled in the lower tune....
My suggestion, try it and see if the sound quality improves. If not, ditch the idea. There isn't enough content to justify a decrease in SQ.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
I assume you mean the difference in volume not sound quality.jdhdiggs wrote:isn't enough content to justify a decrease in SQ.
I actually like the curve I get (when I plot out the bass frequencies) better with one port of my sub blocked, that could just be the way my sub and room work together though.
jdhdiggs wrote:There isn't enough content to justify a decrease in SQ.
I agree with McLoki, that I have to assume you meant volume and not sound quality. My sound quality has not changed but has in fact improved in my opinion, otherwise it would be foolish to keep that configuration. As far as volume goes, if I lost any volume in the upper hertz (which I am positive I must had just because of physics), I sure cannot tell it in my room. I may be one of the lucky ones though.
All I can say is try it and see what you think. Some movies it made a whole new experience to watching it to me. Some movies it made no difference. For instance movies like LOTR made my heart seem to skip a beat with the new settings, while with movies like Pretty Woman, there were no differences.Holydoc (Home Theatre Lover)
Lower tunes in normal size rooms are crazy...
I have a 25-31 model with a free 22hz and I hit 15hz at -4db...
You should expect ATLEAST 2 or 3 hz add on due to your room...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would just check your SPL graphs to see which works better for your room to be honest with you. Yes you don't need max volume, but do look for best curve, because once you are taking about <20Hz, the amount of source material that actually contains these frequencies gets small very quickly. I mean, pipe organs and some drums are about the only things that hit those frequencies in the musical realm. In movies, most sound engineers do not bother because the customer base does not have the equipment to reproduce the sounds, so many will cut it.
it all depends on the fs of the sub the size of the box and power give, if the box is big enough and the fs of the sub is low enough you will gain some low end so it will rool off at a lower fr but at a steaper rate. it is called a ebs or extended bass shelf. but you usaly need a bigger box to get it. i can hit 120db @12 hz now that is bass
