Sub for me system!
audiobliss
audiobliss Posts: 12,518
edited October 2005 in Car Subwoofer Talk
When I finally get an amp in my car (which actually appears like it'll be pretty soon *crosses fingers*), I'll want an amp and sub amp. Due to the same space limitations imposed on my main amp, I'll be going with a Memphis MClass amp, probably the 16-MCD500. For what sub I'm going to use, I really don't know.
I do know I'm going with a sealed enclosure and that I only want a single driver. I've been thinking it'll be a 10". I was originally thinking an 8", but I've decided a 10" would go lower and still be musical. Will a 12" also be as musical? Would it be worth the extra expense?
Now, for brands. If I buy it from the store I'm dealing with, they only carry JL Audio, Memphis, and Alpine. So, which one should I go with? If memory serves me correctly, I can get the 10w1v2 for $250 in a small sealed box. Is that pretty good? I don't know about Alpine's stuff, but what from them would be worth looking at? And what about Memphis; I know nothing about their subs.
I *might* be able to buy the sub elsewhere if it's a pretty good deal and have him still install the sub amp and all. Not sure on that one.
So, what are y'all's thoughts and recommendations on a small, musical sub that I can buy locally? Preferably of the three brands I mentioned, but I'll also consider advice about other brands.
Thanks!!
audiobliss
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • audiobliss
    edited September 2005
    Oh, and I'll need much more help on this subject, because I know a lot less about it. ANY kind of related advice would be very appreciated!
    Thanks!
    audiobliss
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • 1996blackmax
    1996blackmax Posts: 2,436
    I would consider a Soundsplinter sub. I own an RL-i10 (http://www.soundsplinter.com/rli_series/rli_10_inch_DIY_car_and_home_subwoofer_driver_information.html), and I am very happy with the sound it produces as well as the output. It has 20mm of Xmax. This is a little more than twice the excursion that the JL sub has. It can also handle more amplifier power. I know there is more to a sub than just the linear excursion it has, but this sub is also known for producing very low levels of distortion. Check out their site and see what you think. Mike the owner is very helpful. He will answer any questions that you have. Even if they point you to another company.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
    VR3 Posts: 29,513
    8-15" subs can be accurate you bonehead.
    All depends on the quality.
  • hellohello
    hellohello Posts: 428
    could always go for the soundsplinter rl-s model :D
    Picking ones nose signifies a strong sense of self discovery :)
    System in the works: ;)
    PP 6V6 with 12ax7 pre ~ 20 watts
    15" Jensen MOD 8ohm ~ 97db SPL
    DiMarzio HS3 and/or Tone Zone S
  • hellohello
  • hellohello
    or since u mentioned 8's get two mm2084's, the cones are smaller, but u have two motors moving instead of just one, itll be musical, and if u have a small car its more than enough
  • audiobliss
    Yeah, I've heard they're pretty nice, but I'm restricted from buying from a store. So, they're out.
    :rolleyes: thanks
    hellohello wrote:
    :eek:
    Just a lil' too expensive! lol
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • 1996blackmax
    Why are you obligated to buy from a regular store?
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • audiobliss
    Well, I'd probably be inclined to anyways, but it's a moot point because of the parents.
    I'm beginning to think about the Polk MOMO MM2104. That should be pretty nice.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,734
    dude, you have a freakin tweeter next to you. Youre not getting a deal going to that guy for $250. It should be more like $175 for that combo, if they dont want to do that for you than youre getting screwed. Youll be able to find a much better deal at tweeter. If you dont want tweeter to install it then take it back to the shop that you like. If you dont like that install it yourself. I work 35+ hours a week and go to school full time. If I can find time to install in my truck, then you most certainly can find time to install.
    -Cody
  • audiobliss
    Not really. I have two. :D
    Well, like I said; I haven't talked prices with him in over a year, so I don't know what he'll do for me now. We'll have to see next time I go talk to him.
    Yeah, but what're your grades like?
    :D:D:D:D
    Just pickin'.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    i currently have a 3.0
    -Cody
  • audiobliss
    Well, I stopped by Tweeters today on the way home. My friend is still 'setting-up shop' at his new location, so I'm going to wait a while before I go and talk prices with him.
    So, what I found out at Tweeter:
    The same lady was working the CA section that usually is; and she knows no more than what she knew last time (which is just what they told her to say; appearantly that JL Audio is the best!!! Man, I so don't wanna buy from them. Hey, maybe I can go by the one in g'boro? Might be better....this also might be the longest paranthetical clause known to man....must be pretty close...). Anyhoo, it turns out that I can get a JL 10w1v2 in a small sealed box from them for $179.99. The sub itself is $109.99. I asked about the Polk MOMO MM2104 and she couldn't remember exactly what it cost (she appearantly wasn't much interested in looking it up, either). She did say it was about $10 or $20 more than the w1. If I can somehow get a nice sealed box for cheap, I'll probably just get the MM2104; maybe even order it from Polk. That reminds me, I've heard it mentioned before that club members get a discount; would this count? And if so, how much is that discount, usually?
    The more I think about it, the more I want the MM2104. We'll just see how it works out.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • hellohello
    club members get a discount?
  • audiobliss
    I remember reading something like that when someone on the HA side was ordering tweeters for their speakers, or something like that. I'm not exactly sure what the deal is there.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    VR3 Posts: 29,513
    You get a discount + free 2nd day shipping for parts you have to pay for.
    Obviously if it is covered under warranty, this does not apply to you.
  • MacLeod
    MacLeod Posts: 14,358
    Get the MM2104. I have one and love it. Its better than the JL. And you know its true if Im recommending AGAINST JL. ;)
  • exalted512
    woohoo, JL sucks! I must say that the w1 isnt that bad of a sub. I heard it when it very first came out in a local shop and wasnt pleased at all, but i heard it in car about 3 weeks ago and i actually liked it. Now if theyll cut the prices in half for a w6 and w7 they might have something going.
    -Cody
  • audiobliss
    Ok. Whenever I get my highs straightened out and have some more money saved up, I'll be looking for a MM2104.
    Thanks!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • denim
    denim Posts: 79
    edited October 2005
    :)good idea
