Can old Onkyo power Klipcsh or Polk?
Help!
I have an old Onkyo TX-SV414PRO. The manual say "60 watts per channel in stereo mode, into 8 ohms, with no more than 0.08% THD. In surround mode it provides a full 50 watts of power to the left and right front channels and to the center channel as well. The rear surround speakers each receive 15 watts per channel." It has Dolby Pro Logic surround sound. It is about 12 years old.
I am looking to buy Klipsch or Polk floorstanding speakers. I currently only have two front speakers and a sub setup. I might get some rears in the future, which might force me to get a new receiver. I hear HK is good. Anyway I currently have some old bookshelf Infinity Sterling Series 6.5 single woofer with polycell tweeter, which are so easy to power. I have never made it half way the volume knob. Which ever speakers I choose, it will be the smaller floorstanding ones for I want them for highs and maybe mids. I have a Klipsch sub SW12 II, which I have to run wires to first, then from sub to speakers. I am considering RF-10, F-1, or Polk monitor 50. I know the RF-10 are way better than F-1. However, the issue is will my old receiver have enough power to make any of these speakers sound decend? I am considering buying one of the lower end HK to push the speakers I choose. Should I get a lower end HK? However, if my old reciever can push anyone of these speakers, I might keep the receiver for a while. I know the speakers I am considering have different sounds ie bright, smooth. My main concern is having enough power for them to sound good. I do not want to spend $400 on monitor 50 if my receiver will make them sound bad. To tell you guys the truth, the speakers I have now do not sound to bad. That could mean I have never really heard good speakers.
Recap questions:
1. However, the issue is will my old receiver have enough power to make any of these speaker sound decend?
2. Should I get a lower end HK? However, if my old reciever can push anyone of these speakers, I might keep the receiver for a while.
Recap questions:
Post edited by mrod on
Hi Mrod,
Your receiver should be able to push Polk or Klipsch. I had an Onkyo receiver at one time and it had an excellent amplifier section. Klipsch makes some of the most efficient speakers and they will go LOUD with very little power.
When it comes to speakers, it's your call. As you already know, Polk and Klipsch sound completely different. I prefer Klipsch but still love my Polks. If you're going Klipsch, don't bother with the F line. The RF are much better. Save a little more cash and get a pair of RF1-5 or 25. I have a pair of RF-35 and love them very much.
Maurice
