center channel install
fish369
fish369 Posts: 13
edited September 2005 in Car Audio & Electronics
Been away too long from the car audio game. Need some help hooking up a center channel speaker in my ole plow truck. Running Stillwater 3.5 inchers in the dash off a Carver amp. Ran a lead off the right, neg and left, pos speaker to the center, but it doesn't work! Do I need to run the lead off the right and left of the amp? Been away tooooo long.
Fred Fisher
Pioneer VSX-D912K
Pioneer DV-578A-S
Toshiba 6 head VCR
Polk 6800
Mitsubishi 65"
Post edited by fish369 on
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Off topic a bit if someone can add the info: How does the center channel help a 2 channel source in CA?
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Jstas
    Jstas Posts: 14,845
    First off, jdhdiggs, you can get complete 5.1 surround sound processors in your car. The Civic at Polk HQ that was under teh Dodge Magnum had just such a set up.
    However, if I am reading fish369's post correctly, he has wired his left speaker up to the left channel and his right speaker up to the right channel and has then attempted to bridge the left and right channels with a center speaker. With speakers wired to both channels, bridging them to form a 3rd center channel only shorts out the amplifier output circuits.
    fish369, why are you trying wire up a center channel speaker anyway?
    Expert Moron Extraordinaire
  • jdhdiggs
    Thanks John, so basically the same deal as a 5.1 in HA... Hmm, I was hoping it would do more to stear the image to make for the bad shape of a car for better 2-channel performance.
    Wished the keys would have worked on the civic... Would have been nice to goes "ears on" on that setup.
  • Jstas
    Jstas Posts: 14,845
    I have seen setups with SQ in mind use a center tweeter to skew imaging and create depth in the sound stage before. However, it requires some fancy crossover workings to get a single speaker to work. I have seen dual tweeters placed next to each other with a seperate left and right channel set there too and that would be an easier crossover setup. I never liked that idea though. It creates a false image that seems hollow. It is usually bouncing off of the windsheild and causes a sort of time delay in the sound. Usually to get it to work right you need to shove it all the way to the front of the dash at the base of the windsheild. At that point, the problems caused by reflections are too great to overcome easily with electronics and accuracy of the sound reproduction suffers and the sound is muddy.
    If it is a 5.1 channel setup then you need an approrpaite reciever with a DVD or SACD capability and a digital signal processor to handle the Dolby or DTS encoding and video signal. Not to mention the monitor.The biggest problem is that in pretty much every state, the movie can not be playing on the screen while the car is moving IF the screen is visible to the driver. So all these dash units are really useless unless you have a sat-nav system or a touch screen capability. Expensive and complicated stuff but if you have a van or SUV and haul a bunch of kids long distances, a movie theater in the car can be a godsend.
  • hoosier21
    hoosier21 Posts: 4,413
    Old school for sure.
    Here is what he is asking for "The Wired approach"
    http://www.termpro.com/articles/center.html
    You have hooked it up correctly, you sure the center speaker is a working speaker? Checked all the connections?
    "Do I need to run the lead off the right and left of the amp?"
    And it doesn't matter if you connect the center channel wire "+" to the left "+" speaker terminal or the left amp "+" terminal, electrically it is the same. Same for the "-" connections.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • fish369
    fish369 Posts: 13
    Old school for sure, you are the man hoosier21, I can even remember the Jag on the cover of that issue. Exactly what I was looking for!
    Fred Fisher
    Pioneer VSX-D912K
    Pioneer DV-578A-S
    Toshiba 6 head VCR
    Polk 6800
    Mitsubishi 65"
