Hook Up for 2 PSWs
outlawsmj
outlawsmj Posts: 3
I have 2 Polk PSWs. The PSW 404 has an LFE line and the older PSW 150 has RCAs. I have an H/K AVR 230 which has just one LFE. What would be the best way to hook up the 2 subs?
I'm currently running the LFE to the 404 and the RCAs from the sub output to the 150. I guess my question is, would it be better to split the LFE line and run it to the left or right input of the 150? :confused:
I'm up for suggestions before pulling wires and crawling under house for the ole-"trial and error" method.
  • cmy330go
    cmy330go Posts: 2,341
    edited September 2005
    If the old PSW 150 has an adjustable crossover I would turn it as high as possible, split the lfe line from the 404 and set the crossover on your receiver.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
