component vs hdmi dvd player?
tecmo04
tecmo04 Posts: 421
edited February 2006 in Electronics
i am concidering upgrading my dvd player. i curently have the sony svp-s360 hooked up through component video. i am not really satisfied with the picture. i am concidering purchising this one. will there be a big difference in picture quality? is it worth the money? should i wait for more and better ones to come out?
any help would be great. thanks all!
Post edited by tecmo04 on
  • steveinaz
    steveinaz Posts: 19,545
    edited September 2005
    For that price I'd recommend the Panasonic S77. Top notch, non nonsense budget player.
  • Toxis
    Toxis Posts: 5,116
    in that price range, you're not benefitting anything. Either spend $300 for a nice denon or live with what you have.
  • jmierzur
    jmierzur Posts: 489
    Before you rush out the door to buy a new player:
    - What is the nature of your problem?
    - What type of monitor do you have?
    - Do you have a calibration disc?
    - Has the monitor ever been manually adjusted or calibrated?
    By providing some details, the forum may be able to give you better direction.
  • Ron-P
    Ron-P Posts: 8,520
    With in the next few weeks I'll be upgrading my Panasonic projector to the Sanyo Z3 which is a hi-def projector and has DVI / HDMI inputs. I'll need to upgrade my dvd player as well.
    Anyone have one of these newer dvd players with DVI / HDMI outputs and are using them?
    If...
    Ron loves a film = don't even rent.
  • mldennison
    mldennison Posts: 307
    is there really going to be alot of upside to using HDMI/DVI from the DVD player? i would guess that most mid-level DVD players have a pretty good de-interlacing chip in them, not sure how good the one in the Sanyo is. is it easier to do scaling on the digital image than the analog?
  • tecmo04
    tecmo04 Posts: 421
    i have a 32" proview lcd (yay costco) rx 326. i feel like the picture is to grany for my liking. i feel like sometimes the picture doesnt match up with the audio. i dont have this problem when i watch hdtv so i feel like its my old dvd player. maybee its the fact that i bought a cheep lcd but would going to an hdmi cable/new dvd player help me? i feel like goign to a full digital cable would help me.
    i used a thx disk to manualy colaborate.
    any help again would be greatly appreciated!
  • fireshoes
    fireshoes Posts: 3,167
    Just remember you'll be buying a Blu-Ray player in another 6 months or so. ;)
  • PolkThug
    PolkThug Posts: 7,532
    ...and then an HD-DVD player a month after that. :eek:
  • PolkThug
    LCD displays can be grainy, its the nature of the beast. A new player may not help you.
    The best thing I can recommend is to find a store that will let you borrow a Denon DVD player so you can see if a quality player will help.
    Try to find a DVE, Avia or S&V calibration disk. A lot of people have graininess because their contrast is set too high, or their TV is still in "torch mode" from the factory.
  • tecmo04
    tecmo04 Posts: 421
    what is torch mode and how do i know if my lcd is in it?
    billbillw Posts: 7,541
    I second Steve's recommendation for the Panasonic S77. There is very little to fault about that player for the money. Its video output can stand up to all of the the most expensive Denon units (But you definetly won't get the high quality audio section with the Panny).
    Edit: I just noticed what TV you are using. You will definetly see an improvement if you go with a good quality upconverting unit like the Panny S77. Fixed pixel (LCD/DLP/LCOS) TVs look noticabley better with a good upconverting player, especially the cheaper ones (Proscan) that don't have the best built in scalers.
  • millerman 3732
    millerman 3732 Posts: 1,488
    had the same problem with my LCD rptv with the grainy picture, the avia disk help some by dimming down the picture ,that takes a little getting use to but you will, Also ,I have a Samsung hd 931 (w/DVI) and an Onkyo 702 dvd changer (w/componet )and I must say that the samsung with dvi hook up dose have a smoother picture, but I think I would wait on the newer dvd players if I were you
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • steveinaz
    Graininess can usually be attributed to too high contrast setting. Most people run their TV's way too HOT in the contrast/color department for my taste. Also check that your "sharpness" is set to 0. Modern televisions don't need the sharpness set, it only adds grain to the picture. My Panasonic 36" CRT is set like this: (Scale is 0 to 62)
    Color=8
    Contrast/Picture=40
    Brightness=42
    Tint=31
    Sharpness=0
  • tecmo04
    tecmo04 Posts: 421
    thanks steveinaz. turning the shapness to 0 helped. eventualy i will buy avia.
  • tecmo04
    tecmo04 Posts: 421
    does anyone know bb return policy? i still want to try the hdmi dvd player to see if theres any video quality improovment. if i dont like it obviously i would like to return it.
    p.s. another reason i like that dvd player is because it reads divx movies and a multitude of my friends like to download movies and tv shows
    It used to be 30 days as long as you have all the original packaging and parts, but I'd check to make sure. I thought I read that they were getting more picky about returns, so that may have changed.
  • adam2434
    adam2434 Posts: 995
    I agree with Panny S77 recos. I have it connected with HDMI (Blue Jeans Cable) to my Panny AE700U LCD projector. In my system, this produces the smoothest and most noise free picture I have been able to achieve.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • AndyGwis
    AndyGwis Posts: 3,655
    When are HD-DVDs (and I'm guessing HD DVD players) supposedly coming out? I bought a Samsung HD-850 player impulsively after getting a great deal on a Samsung HPR 4252 Plasma TV. Picture is good in component, but seems very grainy, macroblocking, clayface using HDMI. Not sure if it's set up wrong, my DVDs are of poor quality, or Plasma's just don't look great in using HDMI. . . but HD TV looks great on it.
    If you had $200 to spend today on a DVD player, what would you get? I can live with what I have for a few more months as Component looks great, but if I find something I like better, I can hook up the HD850 in the bedroom with component or HDMI/DVD.
    Thanks!
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Ferres
    Ferres Posts: 310
    Some dvd players like the Toshiba have their output defaulted for component which is analog despite using the hdmi connection. It can be set to 'rgb (digital)' via video settings.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
