Need Help with amp/LSi9's
Hey guys, what do you think about using an amp rated at 350 watts/4ohms per ch with the LSi9's.
It seems to me that may be too much power but I am not sure and don't want to mess up the speakers.
Brains: Marant 7701
Power: Adcom 7605 (center & surrounds)
Power: Carver TFM 35x (mains)
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
Control: MX 850 Orion
"One shot, One Kill" Semper Fi
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
Post edited by haveldl on
Your ear drums won't let you use all of the available power. Hook it up and enjoy.
It is extremly rare to have to powerfull of a amp hooked up to speakers, whats the difference if you don't use the power? You could have 1000 watts per channel hooked up to them and they would be fine, because you would never use the full 1000 watts. If you did you would probably be deaf, or push the speakers so hard you would blow them.
I personally use a amp rated at 600 watts per channel into 4 ohms and have never had a problem. Great clean power when I am playing soft background music, or when I am blasting the HT.
Jared -
You won't have a problem. I am running a 500 watt/channel amp into my LSi7's (speakers rated at 150 watts) and it sounds great. If the soundstage starts to collapse, turn it down though.. (you will know you are pushing it by that time though - when you are sending that kind of power to your speakers - its not like it snuck up on you....
Thanks guys. I wasnt sure. My adcom is only 175 watts x 5 so I will use that for the surrounds and center and the more powerful one for the two mains.
Would that be the best way to use it??Brains: Marant 7701
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
"One shot, One Kill" Semper Fi -
Just out of curiosity is the new amp adcom too?HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
cmy330go wrote:Just out of curiosity is the new amp adcom too?
No it's an older Carver TFM-35X that has been sitting in my closet for the last 4 years that I finally decided to use.Brains: Marant 7701
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
cmy330go, how do like that Halo A23? I am considering selling the Carver and picking up that ampBrains: Marant 7701
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
Oh I see. Have you been pretty happy with the Adcom, LSi combo. Just asking cause I'm finally starting to look for inexpensive amps for the HT setup.HT
2 CH
I have no complaints so far with the adcom especially for its price tag. It pumps out plenty of good sound for me.Brains: Marant 7701
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
haveldl wrote:cmy330go, how do like that Halo A23? I am considering selling the Carver and picking up that amp
I love my Halo gear. It is just so smooth sounding. Like many I also think it is stronger than its ratings. I would heavily recommend trying one out if you have the chance.HT
2 CH
