Life is suck but life is GREAT
TroyD
Man, what a BEATING.
At the behest of doing some minor surgery on the Amazings (one of the bases appeared to be unstable so I had to re-drill the bases) which required me to move them to a more conducive location.....I decided to swap around the rigs. Moving 120lb plus speakers by yourself with no dolly CAREFULLY through the house is no small task.
The Amazings now are in the living room with Sunfire tube pre/Silver 9t's and the SDA 2.3tl's are in the cave with the CJ PV7/MV-75A1.
Why didn't I do this a LOOOONG time ago.....both rigs are MUCH improved. Moved the speakers and associated gear this morning and have been listening to each rig all day long.
As I said, life is suck but now life is GREAT.
(pics to follow, for some reason the Kodak easyshare program has taken a **** and I'm too beat to dick with it.)
BDT
BDT
Congrats on your two new-found rigs!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
The 2.3's should sound much better (fuller) in the cave. Your living room was TOO large for the bass to 'load up'.
Good on ya Troy. Ima roll tubes in the Melos, dig on the arrays for a few, and do a couple tugs.
Cheers,
Troy, ya' shoulda pm'd I could've given you a hand after work. No sense getting hurt or damaging the speaks.
Oh, and just to get under your skin:
P. Floyd - DSOTM 2nd press but a good one to compare to the 180g
Alan Parsons - I Robot
Return to forever - Romantic Warrior
I figured they'd be long gone by the time you got out today. -
Wasn't TOO bad...
Russ,
What's the spacing that you have on your SRS's from the side walls and in between them??
Half the middle space = the side spacing.
48" between, 22" to side walls. You need to put that media shelf somewhere else maybe. If you are worried (or hear) side reflections, easy fix is to remove the grilles, and place them on the sides starting within a foot of the front plane of the speakers.
Cheers,
Been spending the last couple of days effing with the setup of the speakers...
It's cool because it's like two entirely different rigs that I *think* sound better than either did previously.
I think the SDA's in a more intimate setting is pure magic. The bass REALLY loads up in a small room. Plus, mating the CJ PV7 with the MV-75A1 just WORKS. In spades.
Out in the living room, I've been messing with the Amazings. Getting them out into the room a ways is a big help. Without damping the rear wall; the bass was to bloated. I'm still blown away at how musical they are and the just wall of sound they produce. They don't seemto play as loud as they really do, if that makes any sense. I've still got a bit of adjusting to do as the image isn't quite what it should be but we are close.
Fun, fun, fun...
YOU SUCK!!!!!
Let me know when your tired of the CJ
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
There are two places that CJ will EVER be. Troy's house is one. Your house ISN'T the other.
Cheers,
You know you have it bad when you keep a tape measure in your listening room. I keep mine very close at hand.................just finished tweaking my placement since getting my first SACD disc today. Very cool amount of separation and the soundstage of this disc is simply huge! Al Jarreau "All I Got". Every little tweak can make a ton of difference with big, full range speakers!!!
Glad you found "2" new systems in your house Troy!
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I have a big day-glo green one AND a level........how the eff else are you going to know if your speakers are positioned correctly?
Tape, level, laser pointer, and survey transit here. That geek enough?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Full on pocket protector geek
****, I got tape down so I know where the speakers go
I marked the positions in pencil on the hardwood floor.
Ok, how geek is this?
I've spent the good portion of the afternoon trying to address the issue of the back wave from the Amazings. I'm a big believer that, unabated, an undamped rear wall with a dipole does more harm than good. Some will say that it helps throw a bigger soundstage, to which I tacitly agree but I think it can be unnaturally large. It also hinders a good image...and depending on your room, cause other issues. Anyhow, I digress...
Anyhow, all day, I've been trying different fabrics on to cover the rear of the ribbons. How geek is THAT?? What did I end up with?? Plain masking tape...
Troy,
You probably know this already but a 1/4" change in angle causes a huge sound shift. Have someone stand between them and push them forward and back until you get "THE SOUND" then set the angle to keep them there. Have you ever done this?
Masking tape behind the ribbons??? I never tried that one.
Huh, I was posting something in another thread and this is at the bottom of the page in related threads or some ****....
FAAAK, Going on 5 years later and looking at the pics....I think I still have 2 things out of any of that....the f*cking TV and the XM tuna. The rest has gone buh-bye. Man, I'd like that CJ amp back....and the Sunfire pre...and the...
Stupid hobby.
They will live again one day I'm sure
Funny the speakers pictures in this thread now sit in my family room.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Cheers,
Russ
I'm with Russ....not sure why this didn't occur earlier. I bet that cave sounds more like your room back in the SDA glasses days....and that was pretty awesome.
The SDA cultists get so caught up in how big they can be, and room recommendations that they often forget that they're quite capable of smaller, imperfect room greatness. But what would we know I guess. If you haven't modified your 20 year old loudspeaker, you're a loser these days.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
5 year thread revival....wow.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I meant all mine in past tense, along with the Troy but it's no less relevant now than it was then. I'm sure you saw the word Carver and immediately got a hard-on.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
good times good timesDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Agreed, I think SDA is actually better in a smaller / imperfect room.....
Right now my rig is:
VPI Scoutmaster
Dodd tube phono stage
Manley Shrimp pre
Sony SCD-555 ES modded by sacdmods.com
Heathkit W5M monoblocks
Quad ESL-988's
thats a pretty hot rig, pretty. Hopefully, the highly trained electronic repair person will finish and we will be up to do the do, cuz its what we do. I got my glasses at the ready.
RT1
