Small, Cheap, good Computer(right, right?) Sub, suggestions?
Schris22
Hey guys,
Quick question. Anyone got any subs that are decent....not looking at something stellar....for my r15 onkyo tx 8211 computer setup? I just need some of that bottom range filled up. I can't seem to find a sub for under 100 bucks...which is more than I have right now for this setup because I have to pay some other stuff off first, but wanted to see my options first and do more research.
I was thinking a simple sealed box. maybe 1 cu ft if not less. Any idea on driver amp combos? Did some searching around PE. My first ported box was ok I wasn't too impressed but well sealed should be harder to screw up.
Thanks,
Chris
Thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
KLH makes some cheap effective subs. I believe Best Buy sells them. You should be able to get one no problem under $100.
Here's your price point, might be a bit big for you...
http://forums.audioholics.com/forums/showthread.php?t=13459
The Dayton 10" is selling for $100. I see computer subs on ebay from time to time as well.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
thats actually the same sub i'm using for my HT....maybe I should upgrade my HT sub and use it for my computer...nah
dorm room this one is adequete...might build a small one sealed soon...
still open to suggestions.
ChrisReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
