Melted MMC690 crossovers!!
PTY@full_bass
Brief Story:
I bought a pair of MMC690 and a pair of MMC650 a couple of months ago.
I installed the MMC650 and the crossovers got melted because of the heat, obviously the speakers dont work anymore. Then I bought some Kicker components, they are installed and working well.
After two months of installing the MMC650 I decided to install my MMC690, and like I already had a bad experience with the MMC650 I decided to check on the crossovers. They are getting extremly hot. They wont last too much if I keep on using them.
Im using a Lightning Audio BOLT 400.4 (75x4 rms) for the speakers.
What do you recommend me? Is there any other crossover I could use, other brand maybe, or does POLK has like heavyduty crossovers?
By the way, I live in PANAMA, I bought those speakers in Dallas, a store called Speakers and Tweeters or something like that. I could make use of the warranty, but Ive just started on installing all the equipment on my car, I dont want to waste more time on shipping them back and forth.
Best regards,
Rod Blasser
Panama City, Rep of Panama.
Best regards,
Rod Blasser
Post edited by PTY@full_bass on
the only time ive ever heard of anyone melting any crossover, not just polk, was when they were quadrupluing the power rating...
Do you think it could be the amplifier?
This is the one Im using: B2.400.4 click here!
What do you recommend? -
Im stumped. I dont think that amp is even capable of putting out enough juice to melt a 100 watt crossover. Maybe if you were bridging the fronts together and clipping the amp but youd have to work to do that.
Can you tell if the crossover is melting from the inside or the outside?
Other than that, Ive never heard of crossovers melting either.polkaudio sound quality competitor since 2005
Could you post a picture of the crossover?George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
OK the actual case of the crossover melted on one side. Im not sure on how to write that in english, is like a round black part, that part exploted.
Tomorrow I will take a picture of it, how do I upload it?
The guy that is installing my basses told me that the problem might be distortion from the amplifier, it has too much gain. What do you think? -
Wait, forget it, Im going to use cardomain.com jeheh
I dont see how. Even if you clipped the hell out of that amp it wouldnt send out more than 175 watts thru the x-over and I just dont see that ruining it. I was running 150+ thru mine for a while with no problem.polkaudio sound quality competitor since 2005
i dont see it happening either...something is messed up.
