Question about line out converter
C-Man
Ok, I've decided to use a line out converter. I've got two Zapco 2 channel amps. I'd like to hook my 200 up to the front two channels, and my 750 will be for my sub. Now, I know I have to hook a converter up for each amp... one to the front channels and one to the rear channels. In my car there are 4 speakers, components up front and two in the rear door. I'd like to run the rear speakers off the head unit power for a fill and run the fronts off the amp. Can I splice the converter into the rear channels for my sub and still use the rear channels for these speakers also? Will this mess up the output to the sub amp? Should I just run all 4 speakers off my 2 channel at 2 ohms and be done with it? I know that would probably be the easiest way to do it for me and just use the rear for my sub alone, but I don't like losing sound quality by running the 200 at 2 ohms stereo...
Chris
Chris
"The Big C"
Post edited by C-Man on
yes, you can still use your rear channels for fill. I dont see why since you said yourself you dont want to do anything thatll hurt your sq, but to each their own
If done properly rear fill can add a little more fullnes to the sound . It all depends on what you like.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Yeah, a few years back I had my amp hooked up at 2 ohm and it just seemed to scream at me and the quality was a little lacking, but I'm sure it'll still sound better than the factory hu."The Big C"
