sda? help
procycle
procycle Posts: 3
edited September 2005 in Vintage Speakers
I have an old pair of polks that I bought used in 90'. they look most like sda 2b's but have crossover and tweeter on top of the cabinet. I give up what are they....I need a replacement tweeter.
Post edited by procycle on
  • hoosier21
    hoosier21 Posts: 4,420
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • procycle
    procycle Posts: 3
    that's close except the base is diff and the tweeters are mounted in a plate with a metal angle coming off the bottom.
  • procycle
    procycle Posts: 3
    my speakers are definately rt12c's, where can I find a tweeter?
  • hoosier21
    call Polk customer service
  • Polk65
    Polk65 Posts: 1,405
    Procycle, welcome to the forum.
    First, figure out which model tweeter you need to replace.
    http://www.polkaudio.com/forums/showthread.php?t=25377
    The original RTA 12 tweeters are no longer made, but show up on the various auction websites. Polk Audio sells a replacement tweeter (RD0194) but it looks different and is a different size. You can see what the RD0194 looks like in the list of tweeters above. If you decide to buy the new RD0194 tweeter from Polk Audio, mention that you are a Club Polk member for a discount.
    To help prevent blowing a RTA-12 tweeter again:
    * Use a high current amp that supports 4 ohm speakers.
    * Read the RTA 12C speaker manual and verify that the correct fuse is installed.
    http://www.polkaudio.com/downloads/manuals/home/12CManual.pdf
  • BobMcG
    BobMcG Posts: 1,585
    Welcome to the Forums procycle.
    Just for future observations: A couple of sure indications a pair of speakers are SDA is the fact that the backs of the cabinets are clearly marked as SDA and one is labeled the RIGHT channel and one is labeled the LEFT channel. You'll also notice an additional connector for the SDA cable.
    heiney9 Posts: 25,503
    Also to be clear...If you decide to go with replacements from Polk you will need to buy (2). Replace both or you will have mis-matched sound which would not be ideal. I'm sure when you call Polk they would've mentioned this, but I thought I'd throw it out there.
