upside down subs?
  • audiobliss
    audiobliss Posts: 12,518
    edited September 2005
    Hmm. IDK Makes sense to me, though. 'Cuase I think the smaller the box, the more the 'resistance', and so the more power required to move the woofer.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,735
    right as long as youre not saying the air pressure inside a small box is greater than in a big box, the air pressure is the same, its just the amount of space it has to occupy is different
    -Cody
  • audiobliss
    Right, the air pressure is the same. However, is it easier to compress air in a larger box than in a smaller box? Or would that be the same, too? 'Cause if it is the same, I think I'm getting confused, as I don't see how the smaller box would then require more power.
    Oh boy...I'm trying to think...somebody stop me!! :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Toxis
    Toxis Posts: 5,116
    MacLeod wrote:
    You wire a midrange out of phase so that it will fire a split second later than the rest of the system but if a sub is firing in all directions, would it matter?
    are you implying that midrange drivers do not fire in all directions? ;)
  • MacLeod
    MacLeod Posts: 14,358
    Pretty much. Not so much in the lower, midbass frequencies but the higher you go the more directional it gets and off axis response is less and less.
  • Still learning
    Still learning Posts: 107
    Now with this i am really confused(sorry for the 1000000 questioning but itll stop once i learn enough) But wouldent the speaker whires be exposed, and in the open? that would be rather unsightly wouldent it? and would you put the sub directly up to the hole and secure it or would you stick it through the hole and secure it?
    KDC-MP5028- Kenwood deck
    Phoenix Gold speaker wire
    Alpine 6-1/2" Type-R Coaxial 2-Way Speakers- SPR17LP-, in side doors
    Alpine 5x7" Type R speakers -SPR-574A-, in the back.
    2 Alpine type R subwoofers in custom box
    1000 watt Alpine -MRD-M1005- AMP
    -Price invested- Over 1500$
    Not the absolute best, but it works like a champ, you can hear it from like 2 or 3 blocks away from your stand point.
  • Toxis
    Toxis Posts: 5,116
    What I was saying Mac is that sound comes from the front and back of all drivers, not just subs. On/off axis is different.
  • Dizzy_124dvc
    Dizzy_124dvc Posts: 27
    Mounting the sub inverted actually helps SQ depending on the sub. For example, if you have an Infinity Kappa Perfect VQ, it's got a humongous magnet, no way that magnet will fit inside a sealed box with the minimum internal volume (0.3 cu ft). So you put the motor outside the box.
    Second, this actually "creates" more box volume (when you're too lazy to build a new box) because hte motor structure isnt taking up space in the box anymore. This depends on the box size. 0.1 cu ft of sub rear end won't matter in a 1.5cu ft box, but it will be bigger in a 0.7cu ft box.
    Some say the bass gets deeper when mounted this way, and attribute it to the volume "gain". Personally, though, I think its because of better power transmission. now the wires go straight from amp to sub, no need for those $2 connectors that used to be in the box.
  • MacLeod
    Gotcha. ;)
    VR3 Posts: 29,429
    Dizzy...
    You can always get like... ya know... higher quality terminals...
