A and B mains
trubluluc
Hi guys-
Does anyone know, if, when listening to both A and B mains at the same time,
does that affect the ohm load to the speakers
the same as wiring two sets of speakers parallel?
...er 8ohm to 16.
luc
...er 8ohm to 16.
luc
Post edited by trubluluc on
No.
Aaron -
A man of few words is seldom misunderstood.
-luc -
What does NO mean, in what context, relating to what, does it mean no way, no help, can't, won't, or some other statement?
Gary -
if it is a a+b then yes you get 2 8 ohm loads in series that is what the + is for if it is a b set of speakers like multi room then nothey take the amp of your suround and amp the b or seccond room speakers
