Tube design ?s
ND13
Can somebody please point me in the direction of a site that shows the differences in tube design?
You know like the differences in "getters" and **** like that.
Thanks in advance
Noel
edit- I mean the design in the actual tube, not tube amp/pre-amp design.
Sorry for any confusion.
Thanks in advance
Noel
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
Generally it is all over the internet in almost useless small bits and pieces. You have to piece it all together. Hopefully someone else has found a single site which sumarizes some of it.
This is dated but they seemed to know what they was doin' back then.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
You might want to try this?
http://home.comcast.net/~enghenry/diy/taste.pdf
Another suggestion (if you don't mind spending some $) is one of Bruce Rozenblits' books. I would suggest "A Beginner's Guide to Tube Audio Design" http://www.audioxpress.com/bksprods/books/bkaa42.htm
EDIT: There are also some primer-type tidbits and some good designs sprinkled around the following, albeit somewhat funky, site:
http://www.boozhoundlabs.com/ -
Thanks Rich, that one will be a good place to star learning on.
MH- Thanks, those will help out, too."SOME PEOPLE CALL ME MAURICE,
