Old SDA SRS...can you change crossover to 1.2?
autoconsortium
autoconsortium Posts: 64
edited September 2005 in Vintage Speakers
If my original SDA SRS speakers cannot handle monoblock amps, can I upgrade them to the newer system the 1.2 has? I need to modify the crossover as well? This is a different interconnect not compatible in any way with the original SRS speakers???? I am good with a soldering iron and making wiring, should the need arise. I just need these old SRS's to be able to run on monoblock non-common ground speakers. I'm not selling these monoblocks, as I prefer the power handling and sound quality of monoblock designs.
Alex Cagann
Polk SDA SRS
Lexicon DC-1 preamp
(2) Lexicon 501 monoblock amps
Parasound CD Transport 1000
Parasound DAC1000
Nakamichi Dragon
Nakamichi RX505
Post edited by autoconsortium on
    SCompRacer Posts: 9,122
    Check out this thread by DarqueKnight. It will answer your question.
    What you can do is make a non common ground interface for them. Go to this site Click on Publications and click on A1 interconnect instructions. It is just an isolation transformer to prevent a direct connection between the speakers.
    What serial number range are your speakers? That will determine what you need to do. Many of us here have run amps in bridged mono. I was lucky enough to get an original Polk non common ground interface with my SDA's.
    A little review here. In this thread, post # 6, BobMcG had said "All SDA-SRS channels have to have a serial number of 5001 or greater in order to qualifiy for AI-1 use." There is a chart posted in many of the AI-1 interconnect threads showing the serial number range for SDA speakers that cable is compatible with.
    OK, I found the chart. Add a pic of an exposed isolation transformer.
