Anyone mount their CSi5 before?
Tritonman
Tritonman Posts: 159
edited September 2005 in Speakers
I would like to mount my center above my screen so that its in direct line of sight to my seating position. If you look at my showcase you will see where the center is currently at..i would like to get it the same spot just mounted on the ceiling pointing down above the screen. My seating position is about 18ft away from the screen so it would be a perfect match..problem is how to mount something that big and heavy to the ceiling? Any ideas?
