MMC6500s ROCK
Siegel1719
Siegel1719 Posts: 28
edited October 2005 in Car Audio & Electronics
WOW is all i can say. I now beleave in love at first hearing. These are amazeing. I love them thats all i can say. There running of one of the 300/2s. Now just gotta finish the enclosure for the MM12. Oh and the Edead did a great job so im happy with it. Knukonceptz wireing is awesome. Very high quality. Just wanted to share and pics of the install will be up within the week.
Jeremy
Post edited by Siegel1719 on
  • MacLeod
    MacLeod Posts: 14,358
    edited September 2005
    And just think, theyre not broken in yet. Theyll sound 5 times better in about a month. Im on my 3rd set of Polk speakers now and one thing theyve all had in common is they really benefit from a good breaking in.
  • unrealii
    unrealii Posts: 268
    What are you powering them with?
    I've got those same speakers in the box sitting right next to me. They are going back to the store because I changed my mind on replacing my db's.
    LSIm system on order =D
    Currently listening to innovation...
    Prior car systems:
    Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
    Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
  • MacLeod
    You should really hook those up before replacing them. The DB's are the entry level speakers and the Momos are the higher end. I really think youd like those Momos better than the DB's. At least give em a listen before you take em back.
  • 1996blackmax
    1996blackmax Posts: 2,436
    He has the same DB's that I have, those baby's are nowhere near entry level :).
    These are the old school DB's not to be confused with the new DB's.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • beardog03
    beardog03 Posts: 5,550
    I`m going to get the momo`s as soon as I can...
    I have the older db / ex set up right now
    I just got the amp..C4oo.4
    can`t wait to hook it up
    The C5oo.1 is my next amp, but I want to get the speaks first
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Siegel1719
    Im useing a c300.2. One for the components and another c300.2 for the sub. Macleod should i take it easy on the speakers for the first month or so then? Just dont wanna blow them. My gain on the 300.2 is at about 11 o'clock. Crossover is at about 100-110 htz. Is that cool?
    Jeremy
  • unrealii
    unrealii Posts: 268
    Yeah, I would take it easy on the speakers for a little while. If you are running them through the polk cross overs then I dont think you need to set an xover on the amp.
    1996blackmax is right, the db's I have are no where near entry level. I wish I could try try the momo's just to see. However, the store's policy is once I install them, I can't return them.
    Prior car systems:
  • MacLeod
    Jeremy
    Technically youre supposed to take it easy on the speakers the first 20 hours or so but I never seem to make it more than 2 before I have to have a little more volume. Just use some common sense and youll be fine.
    One thing though, that 110 Hz may be a little high. The Momos can get a little lower and you may like having them high passed around 80-70. I wouldnt go any lower than that tho.
    Unrealii- Oops! My bad. I didnt notice those were the old school DB's. While I consider the current Momo line to be as good if not better than anything Polk has put out those old DB's are awesome and nowhere near entry level! ;)
  • hrdhtdvr
    hrdhtdvr Posts: 103
    I have a set of MMC s and I just find them really bright ! Hopefully, when I get my sub hooked up, I can feel "Surrounded" by the music.
    Alpine 9855 hu
    Polk/Momo MMC 460 (Rear)
    Polk/Momo MMC 6500 (Front)
    Polk/Momo MM 2104 Sub
    Amp: JL 500/5
    Wires: Street Wires
    Sat Radio: Sirius PNP
    ______________________
    Home
    Kenwood CD 425M 200 disc cd changer
    Denon AVR-2801 reciever
    Mitsubishi HS-U577
    Toshiba -SD1700 DVD player
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • MacLeod
    They will sound bright at first but they will fatten up, I promise you. Plus make sure youve got the tweeters attenuator at -6 db.
  • hrdhtdvr
    hrdhtdvr Posts: 103
    I have the tweets set to -6 and my hu set to run them flat. (I don't have a amp yet, and my hu sends only 18watts rms.) I should be Ok. I don't notice any distortion.
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • hrdhtdvr
    hrdhtdvr Posts: 103
    I am noticing a big difference now. I was beginning to wonder though.
    I got into the polk speakers because of two reasons. First, my friend Dave, swears by them. He has them in his truck and his home theatre. Secondly, Crutchfield recommended them. So with all these people raving about them, I was just a bit suprised when they were so bright. THANKFULLY, they have started to fatten up.
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • audiobliss
    audiobliss Posts: 12,518
    Good! They'll continue to do so, I'm sure.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • PolkThug
    PolkThug Posts: 7,532
    I used to be much brighter, but then I just fattened up.
  • hrdhtdvr
    hrdhtdvr Posts: 103
    I know the feeling. It sucks to get old! :D
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • cam5860
    cam5860 Posts: 632
    edited October 2005
    I have had a pair of these in my doors for bout 4 months now. I have these crossed over at 100 hertz. Althought they can handle 80 hertz on some music if you listen to bass cd's or something with strong bass like rap it's a little more than they can handle. I just found it best to set them at 100 hertz there for you can play all your music and not have to keep adjusting for different music.
  • CrBoy
    CrBoy Posts: 580
    edited October 2005
    But then you have a gap in your sound frequency... i guess you have your sub crossed at 80Hz...
  • cam5860
    cam5860 Posts: 632
    edited October 2005
    yeah i have my subs crossed at 80 hertz. My mids at 100 hertz and my highs at 125 hertz.
