Lsi 7 front, Cs1 center, Monitor30's surround? Crazy idea?
Hi all,
It is too late to return the Center and Surrounds, and I'm likely trading up to the Rti10's for the front. After extensive listening, I do feel the female vocals (Sarah Brightman) don't sound quite as smooth through the Cs1's as the Rti8's. Dang! I wish I'd found this forum BEFORE I purchased the Cs1's and monitor 30's. They did sound MUCH better than similar or more expensive offerings from Infinity, and JBL in the same setting. Oh well!
NONE of the local shops (I live near Oakland California) carry the LSi series- I've got a long drive today if I want to hear them! On the other hand, pairing LSi 9's or 7's as fronts with the Monitor 30's as surround-and Cs1 center makes no sense. Oh well, maybe I'll just sell it all and get a boombox!
Eric
Eric
Post edited by pixels3d on
Get Cs5 if possible and get Cs1 on back.Main: 2xLsi15
Center: Csi40
Surrounds: 2xLsi7
Back centers: 1xcsi30
Subwoofer: SVS PB10-NSD
Asus STX sound card -> Harman Kardon AVR325 -> Adcom Amps -
i personally use monitor 30s as rear surround for a pair of biamped rti10s the monitor 30s sound good with the rti10s. Polk timbre matches all of their speakers to sound good together. Im currently using a smaller Yamaha center but am upgrading to a csi5-Jeff
My System:
Onkyo Sr604
Carver 125x2
Polk Rti 10 (biamped)
Polk Monitor 30
Polk psw10bk
Polk Rti6
polk CSi3
Monster ripoff wire -
The front 3 should all be timbre matched. Anything else will sound like butt.
We agree, you should sell that cs1, and pick up an LSi-C and that will give you timbre match across the front and significantly change the sound of your setup.Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
I'm confused...you talk of RTis, LSis, but own m30s and a CS1. Please clarify. If you want to move into RTis, then get the RTi 8s or 10s as fronts, a CSi3/5 center and leave your m30s as surrounds. If you move into LSis, then 9s,7s and a C, plus a hefty amp to do them justice is optimum. You can drive 25 miles to a Frys to listen to LSis, just don't expect to be blown away. Frys drives all their speakers on AVRs in awful rooms. Usually the RTis sound better in store. That's not the case.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I agree. I think if you do this you can leave the 30's for surround...at least until the next upgrade. That's what I have across the front and look at my sig to see what I'm using as surrounds. Not popular, but they sound fine as surrounds.Things work out best for those who make the best of the way things work out.-John Wooden
