PSW650 sub placement
zgw8
zgw8 Posts: 78
Hi all - I have the RM7500 HT system that I am now using for my 2 channel stereo (plus sub of course) as my room size has limitations for the HT system. I have the sub placed between the end of a sofa and a large teak cabinet. There is about 4 inches on either side. I know this is probably horrible placement for bass. Any comments? There aren't a lot of places for me to put the monster.
Thanks,
Erik
Post edited by zgw8 on
  • fireshoes
    fireshoes Posts: 3,167
    edited September 2005
    Sometimes you just need to experiment a bit with the placement. I would suggest picking up an SPL meter and test tones to measure your bass response in different spots. Every room is a bit different, so it's hard to say what would work best.
  • aaharvel
    aaharvel Posts: 4,489
    Put the sub where you normally sit, turn it on and walk around the room. Wherever it sounds "best" to you, depending on where you're standing, is where you put the sub.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • tenor12
    tenor12 Posts: 9
    I also have a very large sub, and placement was a problem. It ended up in a corner wedged between a wall and the couch, with the drivers firing into the wall with about two inches or so clearance. This placement actually gave better results than having the drivers face the listening position. Being in the corner helped a lot, I think. I wouldn't worry at all about your sub being between the sofa and a cabinet, especially if this also involves it being near a wall. When it's placed you'll probably also want to play with the input polarity.
  • PolknPepsi
    PolknPepsi Posts: 781
    Sub placement can be very important. In our liv. rm. of 12'x 16" I tried it in 4 different locations and it sounded very different in each place.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • wingnut4772
    wingnut4772 Posts: 7,519
    Ditto. I have a 12' X 42' room and placed my SVS PC Ultra all over the HT half of the room 'till I got it right.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
