top or bottom post for RTi6?
jerryk
jerryk Posts: 6
edited September 2005 in Speakers
I hope this is not a stupid question:
Should I wire my RTi6 to the top or the bottom post? Does it make a difference?
The jumper is connected. I am not bi-wiring just normal.
Post edited by jerryk on
  • Holydoc
    Holydoc Posts: 1,048
    The answer to your question is in this thread:
    http://www.polkaudio.com/forums/showthread.php?t=32014
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Willow
    Willow Posts: 11,219
    you can try either but as mentioned, with the jumpers in place, I wouldn't lose sleep over it.
  • faster100
    faster100 Posts: 6,124
    with the strap installed it make NO difference... they are connected. top is tweeter and bottom is woofer if you bi-wire them in the future
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • jerryk
    jerryk Posts: 6
    If it makes no difference then why did I read on another forum post that the jumper is 4ohms.
  • Willow
    Never heard of this before? the speaker is rated 8ohms not sure how the post could be 4. I am no EE but it doesn't make sens to me.
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    That would be an interesting jumper, did the jumper have a 4 Ohm resistor or any component in series with it? If it was just a plain-ol-wire, then it was unlikely that it was 4 Ohms...
    scott
  • thehaens@cox.net
    Jerry
    If you have a multimeter set it for Ohms/Impedance and check the continuity between the end points of your "jumper" let me know what it reads.....
    scott
  • Ron Temple
    Ron Temple Posts: 3,212
    I believe he was referring to the RTi 10s not 6s...
    http://www.avsforum.com/avs-vb/showthread.php?t=577805
    Buckeyefan loves his 10s, but is searching for more power to run them.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • jerryk
    jerryk Posts: 6
    Ron, thanks. The pictures are very interesting. But what does this mean to me? Should I wire my Denon 2105 to the top or bottom terminal? Or should I bi-wire them to both the top and bottom?
  • Willow
    if you bi-wire , you need one set to the top the other to the bottom. If you use one pair of speaker wire , either or top or bottom.
  • thehaens@cox.net
    It doesn't mean that the jumper is 4 ohms. What it is saying is that he is getting a DCR of 4 Ohms when the jumper is attached. When you put the jumper on the top(tweets) and bottom(mid drivers) you are running the system in parellel, this is in simplest terms, as their is a crossover network in between.
    Let me start over. Lets say that their wasn't anything between the terminals and the drivers and tweeters. If the tweeters were 8 Ohms and the Drivers had a 8 Ohm load as well, when you "jumped" them together you would get a 4 ohm load, as the jumper runs the two circuits(drivers and tweets) in parallel.
    With that said, if you have a DCR of 4 Ohms, you have an effective load on your amps of about 5.5 Ohms. I would bet that the nominal impedance on these speakers in the manual says 6 ohms...
    scott
    as for recommendation on where to wire your receiver/amp, you can wire them to either if you have the jumper installed. IF you are going to run a seperate amp, then run the larger amp on the bottom, and the smaller amp on the "top", that would be my rec....
  • Holydoc
    IF you are going to run a seperate amp, then run the larger amp on the bottom, and the smaller amp on the bottom, that would be my rec....
    Did you mean larger amp on the bottom and smaller amp on the top? Just checking incase I ever need to bi-wire.
  • Airplay355
    Airplay355 Posts: 4,298
    yes larger amp on the bottom. the woofer be more difficult to drive then the tweeter.
  • thehaens@cox.net
    You got it right, I edited my response....def. larger of the amps on the tweets......say a parasound 1500 on the drivers and a paras. 1000 on top...
