new center channel
millerman 3732
millerman 3732 Posts: 1,488
edited September 2005 in Speakers
I'am thinking of replacing my center channel (csi400) its alittle to heavy for the set top stand on top of the 60" sony lcd. I thought i might go csi 3 ,but I don't know alot about it, nor have I ever heard one. Would this be a step up or a step down, and would they match my rti6's any closer than the 400. What do you guys think?
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
Post edited by millerman 3732 on
  • aaharvel
    aaharvel Posts: 4,489
    the csi3 and the rti6's were designed to complement each other. The csi400 is an older variant of the rti line itself.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • millerman 3732
    so go with csi 3 or keep the 400
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • aaharvel
    well if space and proper timbre are your primary concerns, then yeah sell the csi400 and get a csi3. The csi400 is a bigger and more expensive speaker so you should get good money for it. Although the csi3 lacks the powerport and biwiring capabilities of the csi400, it's still an excellent performer and imo has a better tweeter than the older model. If you've got your speakers set to "small" and crossed over at 80hz or so, you won't miss anything.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    VR3 Posts: 29,428
    If you have the CSi40... and not the CS400i or CS400 - get the CSi3. If you have the CS400i or CS400, do NOT get the CSi3.
  • aaharvel
    the csi3 weighs about 10lbs less than the cs400i. There ya' go. :rolleyes: :)
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • millerman 3732
    my bad it was the cs400i to many model numbers to keep up with
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    VR3 Posts: 29,428
    Keep it...
    The CSi3 wont compare.
  • millerman 3732
    thanks for the imput ill stick with the cs400i, still a little heavy though
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • beardog03
    beardog03 Posts: 5,550
    The 245i is a good center speaker..
    I have two , and a 400...
    I almost like the 245 better..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • aaharvel
    doesn't sound like audio quality is an issue- if the tv can hold the weight there's no reason to up/downgrade i suppose. the 400's built like a you know what.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • millerman 3732
    it just that the tv is so wide iam afraid over time that the middle could start to sag. and if i build a shelf over the top of the tv i could lose some of the imaging since the tv is already so tall almost 5' 9'' on top of the stand
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
