Stands for FX300i
doctorg
Just got these. Will any of the stands Polk sells work? Anyone got great suggestions? Will be in traffic area of room, so want something stable.
Skip
Post edited by doctorg on
I quess my proposal was out of bounds?
Oh, the bottle has been to me, my closes friend, my worse enemy! -
I am guessing you can't mount them on a wall right? That would be the easiest way of doing it, but there has been some talk in here about a Sonus stand(?) I think that is the one. But if you can mount them on any walls either behind you or to the side of you, you will probably get the best sound.
wall anchors get them up at a good height and dirt cheap too! this is how i have my fx1000's mounted. would also help you save some floor space in your 'traffic' area...
